(Topic ID: 204334)
Can an incorrect coil blow a fuse?
By arolden
2 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by arolden
    #1 2 years ago
    Hi all.
    This might be a stupid question, but here goes. I have a Gottlieb coil (A-5195) installed in a WPC game that works just fine and seems to be the same strength as the original coil. However this coil obviously has a different resistance across the lugs and a different number of windings. So is it possible that this coil could draw more current than the circuit is designed for and be responsible for blowing a fuse?
    My gut tells me "yes, obviously", but just wanted to verify.
    #2 2 years ago
    Probably not enough of a difference in resistance to blow a coil fuse.
    #3 2 years ago
    Yes. But it seems unlikely that your fuse is so close to the maximum current draw that changing to a similar but slightly beefier coil would consistently blow it.
    https://www.flippers.com/coil-resistance.html
    Gottlieb A-5195 11R6 should be about 11.6 ohms resistance. How much different than the coil you replaced?
    #4 2 years ago
    Quoted from YeOldPinPlayer:
    The correct coil is an AE-23-800. All of the 23-800 coils on that page are 4R2.
    #5 2 years ago
    4.2 ohms should be a lot stronger coil than 11.6 ohms. Are you sure it's wired correctly? Is the fuse blowing immediately or does it take several seconds? EOS switch present and adjusted properly?
    #6 2 years ago
    Why don't you put in the correct coil? They're $10.
    #7 2 years ago
    Quoted from RonaldRayGun:
    Because the machine is not close to me - it belongs to a friend. Trying to help him troubleshoot from a distance.
    The coil is for the plunger - no EOS switch. It doesn't blow immediately; seems to happen at random. Just trying to figure out if this coil is a likely culprit.
    $ 2.50
    Doc's Pinball Shop
    $ 99.99
    $ 45.00
    The MOD Couple
    Various Novelties
    GC Pinball
    $ 26.95
    $ 79.95
    $ 69.00
    Id Rather Play Pinball
    $ 69.00
    The MOD Couple
    Third Coast Pinball
    $ 9.99
    Bent Mods
    $ 86.95
    $ 174.99
    CzTV Mods
    $ 229.99
    € 22.00
    YOYOKOPTER MODS
    Metal-Mods
    $ 22.00
    $ 5,899.00
    Little Shop Of Games
    $ 48.00
