Picked up a slugfest project.
Had a row of switches that did not work. Found the supply wire disconnected from the cpu. Reconnected the supply wire and the switch row worked. One of the switches in the row was an opto. While in switch test started to see the opto switch open and close several times on its own than the whole switch row failed again. The opto does not work nor will any of the switches in the row register in the cpu.
Looked for broken wires. Found none. Just wondering if a failed opto could have caused the switch row not to work or do I have a problem in the cpu?
