How are you measuring the coil resistance? Are you unsoldering it? Measuring it in the game you could be measuring parallel resistance from some other coil.
Now, if the coil has gotten toasted, many things could be a possibility. One of those is that some of the coil windings insulation has melted. A coil is made up of a continuous insulated copper wire, wound around a spool. The wire is coated with a clear vinyl to insulate it. If that insulation has gotten hot and melted you now have some places where the wire is touching itself as it winds around the spool. That effectively reduces the number of wraps or 'turns' you have in the coil, which will reduce its overall resistance, increase the current (which does increase the coil strength), and increase the heat to that coil. However, if it were causing the fuse to blow, it wouldn't be on power up, it would happen during game play. For the fuse to blow, you're getting a surge on power up.
During power up, do a bunch of coils fire or seem to twitch before the fuse blows? If so, I'd suspect your blanking circuit isn't working. The blanking circuit keeps the coils from firing during boot of the MPU. If not working and you're getting a bunch of simultaneous coils firing on power up, that could blow your fuse.
Caveat: I'm going by your testimony that F1 has anything to do with coil power...I haven't cracked a Sys11 manual to verify.
