I can't see a coil locking, but then again, it only takes like half a second for the fuse to blow.
The fuse powers several coils, the flippers but also a couple of upkickers, which are hidden underneath the playfield. It's difficult to check all of 'm at once.
All coils have the right resistance, so I don't think any of those are shorted.
When checking Q3 to ground, Q3 makes a buz, the others don't.
Does that mean it's bad?
I used this website on how to test this specific transistor; http://techniek.flipperwinkel.nl/desega/index2.htm#replace
"TIP36c: Put the red lead of the DMM on the center lead or on the metal tab of the transistor. Put the black lead of the DMM on each of the two outside legs of the transistor. The DMM should show a reading of .4 to .6 volts. Any other value, and the transistor is bad and will need to be replaced."
