(Topic ID: 289791)
Can a AE-26-1200 coil replace AE-25-1000 coil
By martymart
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Pin_Guy
#1 3 years ago
I need to replace the left shooter coil on my JD and only have a AE-26-1200 in my spare parts supply.
I was wondering if this is a suitable replacement or do I need to replace it with a AE-25-1000 which is in the machine currently.
#2 3 years ago
Google pinball coil resistance chart. Find the resistance of each coils. If less than .3 ohms or so, you should be ok. Lower resistance than factory = more power. Higher resistance = less power.
*NOTE* .3 ohms is less than 1 ohm. Not 3 ohms.
#4 3 years ago
Quoted from martymart:
There are lots of variables here, length of wire, AWG of wire, plus toss in thermodynamics and the calculation required are extensive; with that being said, the AE26-1200 will be significantly weaker than an AE25-1000 as not only is the wire smaller which increases resistance but there are also 20% more turns on the bobbin (1200 vs 1000). These factors out of the gate make the AE-26-1200 a much weaker coil, but it will also get hotter faster further increasing its resistance and lowering its power.
I would say that this would NOT be a coil you would want to install as it would be at least 30% weaker out of the gate at room temperature and only degrade further from there.
The part numbers tell you everything:
AE-26-1200 is 26 gage magnet wire spun 1200 turns on the bobbin
AE 25-1000 is 25 gage magnet wire spun 1000 turns on the bobbin
$ 329.99
$ 9.95
3,500
Sturgis, SD
$ 29.50
Playfield - Plastics
$ 99.99
$ 19.95
$ 85.00
3,800 (Firm)
Wolcott, CT
$ 72.95
$ 1.00
Pinball Alley
$ 27.50
5,395
West Chicago, IL
$ 17.99
Gameroom Mods
$ 9.95
$ 14.00
Twisted Tokens
Lenticular Designs
$ 65.00
Cabinet - (Alt) Translites
5,400 (OBO)
Pasadena, TX
$ 29.00
Filament Printing
$ 69.99
Great pinball charity
Pinball Edu
