Ok so here's my idea for a mod... with MS Paint to do a horrible job at illustrating my thoughts.
The left side could use something as the right side is busy with Bart and the train (and potential future saloon doors). The back left corner is open and could use something to fill it out.
I was looking at the pops area and there's a flat plastic above the left pop that says Cactus Canyon and it would be easy enough to make a 3D sign mod there.
But you have a desert in the pops, a river/waterfall ramp in no man's land, and the mine all by itself. I wondered if an extension of the mine would tie it all together more like Whitewater.
I'm imagining something like Thunder Mountain at Disney where it's low rock work (so it doesn't block the view to the top rollovers... no one sees the ball in the pops anyways so that can be partially obstructed) with 1 or 2 high peaks, one of which would be on the left wall behind the left ramp flasher.
Now the waterfall looks a lot more tied in, while the desert behind also off in the distance behind the mountains. This would have to be molded to match the mine. 3D printing would look like butt. Is this a good idea and could someone make it?
