Are there any 3D printer files for the train station mods?
Quoted from Jrl80:Are there any 3D printer files for the train station mods?
Not that anyone has posted.
Scrolling through the thread to catch up on posts, when I get to post 11002 with a picture of the underside of a CC playfield…which made me realize that since my LE delivery I haven’t had to lift the playfield yet!?!!?! Can this be possible? It’s so bizarre to get a new pin and not have to do anything except play it…that’s almost taking away half the challenge of pin ownership!
Has anyone else been waiting for Starcade? How many on here received their games from Starcade? Just curious
Quoted from Golgotha:Has anyone else been waiting for Starcade? How many on here received their games from Starcade? Just curious
Mine should be landing tomorrow from Roger
Quoted from Jrl80:Awesome idea! I remember those paints! I’ll have to swing by a hobby shop later and try to match it. As far as crayola option, am I heating the crayon first or just using hot spatula to melt/form into place?
I would heat the Crayola first to soften it. Then apply. You can also just buy a red grease pencil from Amazon. But if your red is a weird red color just go with the Testors as you can mix to match
Quoted from curban:Scrolling through the thread to catch up on posts, when I get to post 11002 with a picture of the underside of a CC playfield…which made me realize that since my LE delivery I haven’t had to lift the playfield yet!?!!?! Can this be possible? It’s so bizarre to get a new pin and not have to do anything except play it…that’s almost taking away half the challenge of pin ownership!
The only time I’ve lifted my SE pf (in almost a year), was to install the shaker motor. And that, imo, is the best mod out there for this pin especially. Very immersive shaking
Quoted from MrMikeman:The width of the head is the same whether it’s up or folded down…. About 29 inches.
Great thanks
LE ? Delivery tomorrow I didn’t pick a num, I just said what ever comes in next batch to me quickest. I’ll post when I get it thanks for this thread it will still come in handy after I have the game tweaks issues
Quoted from moonraker:Great thanks
got the tape measure out, 28 11/16" to be exact for my machine. I assume pretty much the same for the rest. Hope you can find 11/16th more room.
Quoted from RickyBobby1:got the tape measure out, 28 11/16" to be exact for my machine. I assume pretty much the same for the rest. Hope you can find 11/16th more room.
Yes I should be fine if I pop the door off which shouldn’t be bad it’s cheap interior door three pins
Quoted from Pizza-Bob:Anyone having an issue with their topper staying in lean back position?
Not sure what you mean, he is spring loaded and springs forward when pulled back. A solenoid fires to make him fall back.
here's the innards, shows the springs #5.
Quoted from CoolCatPinball:The beer mug is absolutely OBNOXIOUS when it hits the glass. I'm talking like pinball smacking the glass obnoxious. I put a small post rubber on the beer mug "stem" under the playfield to limit its travel. Trust me, you don't want it hitting the glass.
EDIT: If you do actually want to experience the mug smacking the glass, just remove the locknut from the beer mug stem under the playfield (see my post below) and enjoy
Ok I’m definitely going to paying attention to mine coming tomorrow esp since I have invis glass on order. With my luck it will shatter
Mine registers probably 95%, and has never hit the glass once. I just put invisiglass on ehoh, and hit probably 20 times, I'll be putting some post rubbers on it tmrw .
Quoted from Ivanhoe:Tonight, after 18months of waiting, the whole family is together! [quoted image]
Wow! Absolutely beautiful family right there, super jealous.
Ok, now pick your favorite child!
Are they all matching #'s???
Yes, mine is doing that and at least a couple others have been mentioned previously as doing the same. There are two springs that are supposed to pivot Bart back to the upright position but mine has a lot of drag in the movement.
Quoted from chillme:Not sure what you mean, he is spring loaded and springs forward when pulled back. A solenoid fires to make him fall back.
Mine is getting stuck in the leaning back position and has significant drag in movement, I'm assuming the others having this issue have the same problem.
I’ll take a look at that . Thanks
Quoted from jchristian11:Mine is getting stuck in the leaning back position and has significant drag in movement, I'm assuming the others having this issue have the same problem.
I didn’t have this problem at first . I can’t leave him in the shot potion, I have to do something about this !
Quoted from t2000:# 446 just delivered
Nice! 36% through!!! Wahoo!!
Having replaced several newer stern decals both head and cabinet, the removal was cake. I wouldn't be concerned at all about removing the old one. The part that takes more expertise is aligning it to get it 100% straight. It's still not super complicated as there are various methods you can use and it just being the head makes that much more simple. I wouldn't hesitate to do it if you can get the decal from PPS or whomever your distro was.
yup, we've had ours for a few weeks and haven't lifted the playfield either. Everything is working great. Other than installing the glass backglass haven't done a thing but play it.
Quoted from bigdog50:Are they all matching #'s???
No, I couldn't make that happen.
Does anyone have #626? It might not even be an option, but that would be very cool to have my anniversary June 26th Does anyone know if there is any way to get that number? Is there a process? My game is coming from Starcade by way of PPS. Any insight would be appreciated.
We wanted to wait until the morning to release the day 7 mods, but we will be on our way to TPF and didn't want anyone to miss out on seeing our final release of this event, so we hope you enjoy! Also go see the other release threads as we are starting to get some videos out on some of the items (primarily the aprons)
cc1 (resized).PNGcc2 (resized).PNGcc3 (resized).PNGQuoted from kapaun:Are we expecting any new mods from BackAlleyMatt this week?
Yes. Tomorrow.
Edit: Oops. I guess tonight.
(Links not active yet, but FAQ entry updated)
I paid final invoice a little over a week ago and Roger said could be around 10 days or so. I haven’t heard anything yet.
Picked up a CCr LE # 397 last week.
One thing that irritates me on the shaker is that I like it to just move the pin, not be some jackhammer trapped in a pinball.
Factory settings don't slow it enough for me, if the glass rattles, it's too much.
I have these in both my MMr and CCr now.
CCr multiball still gets the glass rattling, so a very cheap and fast fix was to install a DC motor control (make a simple harness and no cut wires!).
This gives you a dial for the shaker to dial in whatever speed you like!
https://www.amazon.com/gp/product/B071NQ5G71/ref=ppx_yo_dt_b_search_asin_title
CCR Shaker (resized).jpgQuoted from Teknotoyz:Picked up a CCr LE # 397 last week.
amazon.com link »[quoted image]
The first thing I do to all my shaker motors is reposition the weights to lower the effect. Not sure everyone is aware this is an option. DC motor control box is an interesting idea though.
Quoted from SlapDrain:The first thing I do to all my shaker motors is reposition the weights to lower the effect.
I have done that in the past, no where near as good as the motor control. Very refined and still moves the machine with full effect to the level wanted.
Stern node boards do NOT like the controller, so don’t do this on a Stern.
Can you expand on how that is done?
Quoted from jfh:Can you expand on how that is done?
I have a spare shaker out of the game. I’ll take some pics.
It's actually pretty easy and works very well. VPIN community has been using these for a long time - pretty much since real shakers started going into vpin cabinets. Some simple wiring hooks and you are off and running.
The weights are held on with an allen key set screw. Remove the weight and move the set screw to the other threaded hole. Now the weights will be offset by 45 degrees and will be less violent when they rotate. By default they are inline with each other and is a huge amount of weight being spun around. I make this change on all my stern, jjp, and now cgc games. (Stern shaker pictured)
*Be sure to use blue loctite on the set screw during reassembly. You dont want one of those weights flying off or coming loose during operation.
IMG_2112 (resized).jpgIMG_2113 (resized).jpgIMG_2114 (resized).jpgIMG_2115 (resized).jpgIMG_2116 (resized).jpg
Quoted from SlapDrain:The weights are held on with an allen key set screw. Remove the weight and move the set screw to the other threaded hole. Now the weights will be offset by 45 degrees and will be less violent when they rotate. By default they are inline with each other and is a huge amount of weight being spun around. I make this change on all my stern, jjp, and now cgc games. (Stern shaker pictured)
Thanks! Will create a FAQ entry for this later.
This page was printed from https://pinside.com/pinball/forum/topic/cactus-canyon-remake-club-new-sheriffs-in-town/page/222 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
