(Topic ID: 39810)
Cactus Canyon - F101 F106 Error No 12v working.
By woofer768
10 years ago
#1 10 years ago
Hello,
I have a Cactus Canyon that I did a minor shop job (rubbers, clean playfield...). I took all the parts off and put them all back. Although I am lacking in repair experience, I have done this with over 15 working tables so far with little to no problems.
When I turned on the table after reassembling it, I got a "Check fuses F101 and F106, J127 and 12v opto power".
All fuses are good (this includes F109). The LED100 light (12v reg) was out. When I unplugged the power output from the power board (J101) the light would come back on.
I am lucky that I have a lot of tables here, so I swapped the power board from a No Good Gofers and the 12v led problem DID transfer to the No Good Gofers so I figured I was home free. When I put the No Good Gofers Board into the Cactus Canyon, the 12v light now lights up just fine but I am still getting the same error. I have no power (no led) to the main opto board and all my optos on the table are out (optos are normally closed, right?).
I have not checked the voltages at the TPs yet. I will get to that tomorrow.
I am hoping someone can give me some diagnostic ideas. Should I disconnect the opto board? If I do, do I pull all four connectors off or just two. Will That tell me something? Can someone tell me which connector from the power board supplies the power to the opto board?
Anything will help me. Thanks in advance.
#2 10 years ago
Manual in the rear has a connector page along with the driver board so you can see connectors, wire colors, and where they go.
I'd check the 12 volt test point on the driver board and go from there, if low or gone you lost one or more of the big fat diodes. If 12 volts is good, then you have bigger problems.
#3 10 years ago
Hello,
Thanks for the reply LTG! I have checked all the tps on Cactus Canyon and here is the result.
TP100 - 11.64
TP101 - 5.13
TP-103 - 14.4
TP-104 - 23.5
TP-105 - 75.7
All of these readings are similar to the Gofers table... except for:
TP-102 - When the power driver board is all plugged in on CC, I get a reading here that fluctuates quickly between 15v and 18v. If I unplug all the J connectors from the driver board except the power input and output, I get a steady reading of 19.9v. Also just like No Good Gofers.
Any Idea what this is telling me? Do I start pulling out the J connectors one by one until I find the one that is wacking out my 18v (TP2)? What do I do then? Is this my opto issue?
Trying to get smarter. Thanks in advance.
#4 10 years ago
Hello,
I have isolated the 18v issue (if it is actually an issue) to connector J121. When I unplug this, TP2 reads 19v steady. When I plug it in my 18v ranges around between 15v and 18v.
However, just to complicate things, in my manual, it says that J121 is not used.
Still not sure if this is part of my F101 F106 error.
Thanks,
norman
#5 10 years ago
Quoted from woofer768:
J121 and J123 do the same thing, so you can use either one.
#6 10 years ago
Thanks LTG,
Should J121 be making my 18v fluctuate?
#7 10 years ago
If there is an issue on that line out in the game it could be dragging it down.
#8 10 years ago
Never mind...
I see now that J121 are lights. I am guessing that the ranging around that I am seeing is the load of different lights going on and off.
However,
my error still persists...
#9 10 years ago
We crossed posts,
Could this 18v issue have anything to do with my 101 error?
#10 10 years ago
Hello,
Just wanted to let everyone know what happened in case it helps someone else. I my case the problem was that I lost the ground (somehow) for the 12V. Unfortunatly, it came back all by itself and I can't break it again. If it reoccurs, there are several places I could lag the ground back in again.
However, the interesting part is that the error I was getting (check F101, f106, j127) was because the CPU board did not see the ball trough. If you lose the 12v to the ball trough, the F101 error will fire off right away. Hope this helps someone.
#11 10 years ago
I say you give up on the problem, I'll take her off your hands. haha
$ 649.95
Pin Stadium Pinball Mods
Led
$ 9,250.00
Classic Game Rooms
KAHR.US Circuits
Gweem's Mods
Sound/Speakers
$ 89.99
Led
Pin Monk
Other
RavSpec
Toys/Add-ons
NO GOUGE PINBALL™
Other
$ 85.00
Cabinet Parts
Mödley Crüe
Cabinet parts
$ 54.95
Filament Printing
Other
$ 219.00
Lit Frames
Decorations
Precision Pinball prod.
Flipper parts
$ 399.00
Decals
$ 8.00
NO GOUGE PINBALL™
Other
Arcade Upkeep
Other
$ 95.00
Pinball Mod Co.
Sound/Speakers
$ 1,139.00
$ 54.99
Shooter rods
$ 5.00
Protection
$ 24.95
Pinitech LLC
$ 54.99
Shooter rods
$ 119.99
Displays
FlyLand Designs
Displays
$ 69.99
Pinball Shark
Shooter rods
$ 399.95
Led
PinSound
$ 52.99
Pinball Shark
Shooter rods
$ 84.99
Displays
FlyLand Designs
Displays
$ 109.95
PinSound
This page was printed from https://pinside.com/pinball/forum/topic/cactus-canyon-f101-f106-error-no-12v-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
