Pinball Plating and More (www.pinballplatingandmore.com) and Planetary Pinball Supply (PPS) announce availability of Cactus Canyon serial number plaques.
PPS has partnered with Pinball Plating and More (PP&M) to make available Cactus Canyon serial number plaques with some new plating options. PPS had contracted with the original supplier who had original molds for the plaque to produce more plaques, and these are available now. Pinball Plating and More will provide custom serial number engraving as well as provide additional plating options in Polished Brass, Silver, and Gold 24K in addition to the original dull satin brass finish.
Both engraved (with serial numbers) and without will be available. PPS (www.planetarypinball.com) will have on it’s website un-engraved plated plaques in all 4 plating options, and www.pinballplatingandmore.com will be the sole provider of engraved plates which can be in a variety of plating options as well. Customers can order multiple plaques with their serial number in different plating colors if desired.
Pricing for the plates is as follows:
Original Plate (Satin Brass): $79 Not engraved $89 Engraved
Silver, Chrome, Polished Brass (shiny) Plate: $99 Not engraved $109 Engraved
24k Gold Plate: $109 Not engraved $119 Engraved
Also – matched mounting screws will be available for $9 (set/4) which will be plated in any of the 4 plating options to match the serial plaque plating if desired.
Note: for ENGRAVED (with your serial number) these are available only from Ron Woodard at Pinball Plating and More ([email protected]) – for Not engraved these will be available from either PPS or PP&M – plates are in hand and will be available on each store very soon.
Thanks to all for your interest and we are happy to finally make these available.
