(Topic ID: 134120)
Cactus Canyon Cabinet Restoration
By ncbk_br80
  • 28 posts
  • 14 Pinsiders participating
  • Latest reply 3 years ago by ncbk_br80
There have been 83 images uploaded to this topic. (View topic image gallery).
#1 3 years ago
Recently finished up this Cactus Canyon cabinet restoration for a fellow Pinsider.
I was asked to just tackle the cabinet, the playfield was sent to Captain Neo for touch-ups/clear-coating, and the owner will do the re-assemble and install. Nothing ground breaking with this cab restore, just wanted to give it the attention this title deserves. Pictures are more fun to look at than reading, so I'll keep my commentary below to a minimum.
Fairly standard, beat-up, routed cabinet:
#2 3 years ago
Sanding begins along with bondo work:
#3 3 years ago
More bondo and sanding:
#4 3 years ago
Tape-up and Primer:
#5 3 years ago
Can't forget about the Backbox:
#6 3 years ago
What's with this bottom section? More bondo needed:
#7 3 years ago
More Primer and time for the DIY Paint Booth:
#8 3 years ago
Wood Panel for front decal, plus 2PAC cleared the Backbox Warning:
Jim McCune trick for front decal panel.
#9 3 years ago
More cab decals installed:
#10 3 years ago
Final Pictures:
#11 3 years ago
Awesome job, man! Beautiful restore!
Great line-up in the back too. I see some last-played scores on at least two of the machines, I assume you took some well needed pinball breaks while doing this project? Haha.
#12 3 years ago
Owner is going to be very happy. Looks great and fun game.
#13 3 years ago
Yes, I think the owner is going to be very happy!! Outstanding work!!
#14 3 years ago
Very nice. Thanks for sharing.
#15 3 years ago
Kudos and accolades to you for a great job.
#16 3 years ago
Looks great,what was the time frame to redo the cabinet.
#17 3 years ago
What would be cool on threads like this, to go with the pictures of the various finished stages, is pictures of the tools/products used. Unless that's all a big secret.
#18 3 years ago
Quoted from pingod:
Thanks all...it took about a month to finish everything up
Quoted from epthegeek:
No big secret at all, if you have any questions...fire away. But the tools & products used were nothing special...Milwaukee Heat Gun + metal scrapper, All Purpose Bondo & Dewalt Orbital Sander, Paint and Primer, and lots of generic elbow grease.
#19 3 years ago
Killer job Pat, you're gonna have to watch out or you're going to be the go-to restore guy in SoCal!
I was going to get Pat to do my EATPM, but when I brought it over a friend of his made me an offer I couldn't turn down so I sold it instead. But I'd trust him with any of my games in a heartbeat, I've seen his work in person, and it's immaculate.
#20 3 years ago
Hmm, I've got an F-14 cabinet that's in need of work...
#21 3 years ago
Curious about sanding process. All with an orbital? What grit to start and through finish?
Also curious about painting / priming. Assuming a paint gun? What one?
These threads make it look so easy. But I know it is a lot of work!
#22 3 years ago
Quoted from RobertWinter:
Robert, talk with Pat, he's a great guy, and does awesome work. He's seriously obsessive, it's a little ridiculous. But in the best way.
#23 3 years ago
Robert, I'll send you a PM...funny thing, your old website with the Cactus Canyon restore is one I referenced for this project.
Quoted from Elicash:
For the sanding, it was mostly with the orbital, some by hand. Started with 120 & 150 grit..then onto 220 and 320.
The painting was done with a cheap harbor freight purple gun, but best place for restore guidance is Bryan Kelly's thread:
It's the mecca of restore knowledge - https://pinside.com/pinball/forum/topic/ij-restoration-started
Quoted from Aurich:
Admittedly, yes a little ridiculous sometimes...it's the rare case where some minor OCD is a benefit.
#24 3 years ago
Just a friendly notation as we crossed this bridge when we did my CC decals last year.
We ordered a new set from PPS last Sept, they were applied and properly lined up with the barbed wire Ect. Once the legs were installed, part of the black block that shows the color test cubes on the coin door decal, was visible when the legs were put on. The factory decals did not have this to start. Since the PPS decals were supposed to be from the original films, PPS was contacted, they ultimately re-ran the decals and omitted the black and color test cubes. We had to install all new cab decals so the coloration, and texture matched. First pic was my OE factory decals, next 2 are the Next Gen replacements. Check your legs and see what you get.
#25 3 years ago
Quoted from HighSpeed1:
I notified Rick about the CC decals being screwed up January 2013. The problem is the black on the sides is supposed to go to the rear of the game but they printed them wrong because they used the right side decal for both sides.
Game turned out OK even with a small blemish .
https://photos.google.com/album/AF1QipNqOt822w-1xIVKNnM79zPCVnWWoaK9TSrGCkcD
#26 3 years ago
My Game is HUO, I'm second owner and never saw them front or back on the OE decals, then again the right side was so wrinkled the whole length of the game, when I peeled the decal off, I found 3 layers on the right side, each one revealed that someone at Williams applied them crooked twice continuing to layer another one over the top till they got it right.
#27 3 years ago
Can I ask what black paint did you use for the cabinet? I did a CC and MB restore years ago and found painting the cabinet black made it really hard for the corners of the decal top stick. I thought I screwed up and should have left it primed. I will be doing my FT decals in a few months and would appreciate any tips.
PS> Fantastic job!
Quoted from BR80:
#28 3 years ago
Interesting about the decals, I wondered why the sides didn't have the same color bar as the front did...glad it was the newer set.
Quoted from Edster:
Under the decals, used a standard semi-gloss black rustoleum paint. But I don't think the type of paint would cause your decals to stick any better or worse. My guess would be the adhesive on the decal being the issue before the type of paint underneath.
PCB Emporium
$ 89.99
