Quoted from bam10:So the bumpers the game rests on are in new section, or just above where you spliced it? You feel like this will hold up better then the factory particle board to being dragged?
Don't recall specifically where I placed the new bumpers, but looking at the photo I'd guess they are in the new piece for the bottom two, and yes, I believe the plywood will hold up better than particle board.
On another note, I did note show any photos of the bottom of the KISS cabinet. Instead of the typical 1/4" bottom material that is routed in with a 1/4" gap at the bottom, I chose to route the bottom of the cabinet 1/4" into the walls by 1/2" from the bottom. Then I used 1/2" plywood for the bottom. The result is a much stronger bottom that is flush with the bottom edges which will prevent chipping from dragging in the future. The result inside the cabinet is the same as the original. I chose this route because these days we move games with hydraulic lifts the stress the old design.
If you have a game with the bottom falling out, you can route the 1/4" lip at the bottom away and remove the old floor. You will end up with a 1/2" routed bottom and then you can just glue and nail in a new piece of 1/2" plywood.
