How are people applying the metallic paint speckle to early (late 70's early 80's) Bally cabinets?
I've heard of people using a toothbrush. I'm certain the factory used some kind of HVLP set or adjusted for the right pattern. Any thoughts from the restoration pros here?
If you're using HVLP, what adjustments do you make? What pressure? I have some old, cheap, $12 HVLP guns that I could modify if I knew how.
Example of the original gold speckles:
Thoughts? vid1900 @high_end_pins? Thanks all.
