Hey all,
If a machine has cabinet damage like splintered wood, is there anything that can be done to repair it (other than replacing the entire cabinet, or are you stuck with it?
Thanks in advance!
Hey all,
Thanks in advance!
Hey Jim,
Is it best to use auto body filler for that kind of damage or can you use the quikwood filler? If it is auto body filler that you recommend is it the kind that can be bought at Home Depot or Lowes?
Loren
You will want to of course make sure whatever you're starting with is 'clean', meaning no flaking/splintering areas. Remove all the damaged wood. Filler will 'stick' better on a coarse surface than a smooth surface. You could drill a series of small holes to give the filler a little more material to 'bite' to.
How you repair a spot really depends on the size, location and how bad it is.
Also, you can't apply a ton of filler in one sitting. You need to build it up over a few sessions if it's a huge gouge/hole/dent, etc.
Stuff like a hole for a hasp is better filled with a hardwood dowel, and then use your bondo/wood putty/etc to make the end repair smooth.
Post some pics of what you're up against, and I'm sure someone will give you a good plan of attack!
This page was printed from https://pinside.com/pinball/forum/topic/cabinet-damage-how-to-fix-it and we tried optimising it for printing. Some page elements may have been deliberately hidden.
