Here are tips that will shave off a lot of time.
1) get glue remover (the type that applies with a brush) high strength
2) wait 5 minutes after applying the solution and hit it with your wife's / girlfriend's hair dryer by going over it but not staying at the same spot. The reaction will go faster. Make sure you buy 3 pair of gloves that shit eats through glove in no time and make sure you wear protective eye-wear.
3) Take the drywall throwel (or whatever you call it) and scrap off the vinyl. This should be really easy now that the solution as had the time to eat through the glue.
4)Rinse and repeat in the harder areas....the solution might have a harder time going through darker colors.
5) hit the bare side with a splash of more glue remover and then use the wood scraper and take off as much glue as you can. I cannot stress this enough because it's a lot easier to remove the remaining glue now then to try and sand it out later. The glue will get into the pores of the sandpaper quickly and you will find yourself change sheets every 2 minutes.
6)Once the cab is all sanded down, run your fingers across the panels. They will detect a lot faster all the imperfections. Your eyes can miss a lot of them. Take a pencil and circle the imperfections. That way once you get to the bondo stage you will have a clear indication of where to apply it.
7)The painting part is the hardest and most time consuming. If you have the intention of doing more cabs in the future then I suggest you get a compressor and a paint gun. Those will save you alot more time and create a more professional finish. I usually put light coats of primer until the surface is fully covered. Sand down imperfections and check once more for holes.
8)to do a real good job you will need at least 4 coats of paint. and then you sand down the imperfections and do compound sanding (400, then 600, then 800, up to 2000 if you want to), depending on the paint you used you might not even have to do this but one thing for sure the surface must be 100% flat. even a small grain of dust will make a mountain the size of the grand canyon on the panels.
in a nut shell this is it.
