New! Dark mode!
(Topic ID: 262740)
c-clip / snap ring tool?
By Bendit
8 months ago
  • 24 posts
  • 14 Pinsiders participating
  • Latest reply 8 months ago by cjchand
    #1 8 months ago
    I apologize in advance for my ignorance. Jeez.
    I am looking for a tool to remove the c-clip (or whatever they are called) from the shooting rod on TSPP.
    Found a bunch of tools on amazon, but most look big and for automotive use.
    What do you guys use?
    Thanks in advance for your time. This should be easy but I have no experience with c-clips at all. Cheers.
    #2 8 months ago
    needle nose pliers.
    #4 8 months ago
    Yup no special needed; Needle nose always good. You can use a small screwdriver too but the clips tend to shoot off and disappear.
    #5 8 months ago
    Get a snap ring tool. They are cheap. Yes needle nose work in a pinch but you will never lose a clip again with the right tool especially if you are trying to get in hard to reach places. Mine came from radio shack many years years ago and had several attachments for diffferent clips. They are cheap.
    #6 8 months ago
    Quoted from PBFan:
    Pics of your tool? I just need to know what tips are on your pliers.
    Thank you all for your input! And thanks for the long links!
    #7 8 months ago
    Nope
    #8 8 months ago
    But, be sure to pull spring and washer back first. Should be able to just nudge clip up with small screwdriver and pop off with hand.
    #9 8 months ago
    As requested. This one allows u to use the same tool for inner and outer snap rings or clips.
    A23EDA0F-05EF-4970-B081-D5B586B09957 (resized).jpegB6BC644C-CB98-44F8-BA96-8DADB26ABC8E (resized).jpeg
    #10 8 months ago
    snap ring =/= e clip
    Use a needle nose to remove e clips.
    #11 8 months ago
    Needle nose pliers slip off, needle nose vise grips are perfect and will never lose the grip. Those snap ring pliers shown are for C clips that have tiny holes in the end, none of the C clips on a machine have holes in the ends.
    #12 8 months ago
    Quoted from Bendit:
    Pics of your tool?
    Nope, not sending any pics of my tool.(not on a public page, anyway...)
    #13 8 months ago
    Quoted from RocketFromTombs:
    ummmmm what?
    #14 8 months ago
    Quoted from tomtest:
    Exactly! That's what confused me.
    Quoted from PBFan:
    Thank you Sir!
    e clips?????
    If you use needle nose pliers, don't the c-clip stay bent after they are removed?
    So it's not worth it to get the c-clip pliers since the c-clips in the pinball machines don't have holes in them? If it's still worth it to get the c-clip pliers, which "tip" do you use?
    #15 8 months ago
    This maybe the weirdest response I’ve seen
    #16 8 months ago
    for c clips i use a needle nose plier or pick tool to remove. the pick tool to prick the clip off into my hand.
    #17 8 months ago
    Quoted from robotron:
    I have a pick set. I have needle nose pliers. I will try using them!
    Thanks guys! Cheers!
    #18 8 months ago
    Quoted from Bendit:
    e clips?????
    C clips = E clips. They are shaped like a C, but also have the middle nub, looking like an E.
    Listen, you can buy anything you want and buying tools is fun, but this is totally over thinking it. This specialized tool will not make your life any easier for removing C clips, all you need are needle nose pliers.
    You yank the thing off, and 97% of the time the clip is fine, use your pliers (multiple uses! ) to bend it back a bit for the other 2.5% it's not fine.
    Head to the hardware store if you need to buy more c clips
    #19 8 months ago
    Quoted from TheLaw:
    Thanks. Very important piece you added. The cumulative knowledge listed here is making me comfy. Thanks again!
    #20 8 months ago
    Quoted from Bendit:
    Yeah we all have to learn. The funny part is this thread took 1000 times longer to read than removing the clip
    #21 8 months ago
    Quoted from TheLaw:
    True. But you also need factor in the many hours spent looking where that little clip lands after it flies across the room because the wrong tool was used.
    #22 8 months ago
    Quoted from TheLaw:
    Good to see a lot of patience in this thread too. Many threads like this go south so kudos to all who realized just what Law said and offered help.
    #23 8 months ago
    I use a flat head screwdriver to pry it off, but keep my other hand over it so it flies into my hand, and not into orbit. I used a pliers to install it. I don't have a ton of luck trying to pull it off with a pliers. Seems to always slip off.
    #24 8 months ago
    https://www.harborfreight.com/snap-ring-pliers-with-interchangeable-heads-63845.html
    For $4.99 (pre 20% coupons they keep spamming me with) might as well get the right tool for the job.
    $ 14.95
    Various Novelties
    Allteksystems
    Mods for your pinballs
    Filament Printing
    $ 27.50
    The MOD Couple
    $ 7,299.00
    Classic Game Rooms
    $ 14.95
    $ 48.00
    $ 36.00
    Pin Monk
    $ 22.00
    ScottyMods
    $ 89.99
    $ 175.00
    Professor Pinball
    $ 29.00
    $ 65.00
    Pin Monk
    $ 14.95
    $ 48.00
    $ 395.00
    M&M Mods
    Creo Pinball
    $ 48.00
    $ 48.00
    $ 49.95
    $ 259.99
    Apparel - Unisex
    ArcadeMade
    Metal-Mods
    $ 4.49
