Quoted from Occelot:Hey guys, In theory, if a solenoid itself is causing a short, I should be able to remove the solenoid, and splice the wires (50+vdc) from the lugs together and it shouldn't blow the fuse right? Figured I'd run this by you before I tried it. I guess in short, the question is, can I simply remove the solenoid out of the circuit and patch the in/out leads together.
That's a DEAD SHORT, and WILL FRY SOMETHING (hopefully just more fuses, but probably more)....
Think of a coil like a light bulb, hot power goes in one end, the bulb is a load that does something (heat and light), and the power goes out the other end to ground.
If you short the two wires going into a light bulb you get a short and a FIRE. Go stick a metal paper clip into the two sides of a socket for an example, if you really need one (I'm am not responsible if you really try to do so).
Coils are also wired much like the wiring in your home, where the wire comes from the power source, goes to one outlet, and another wire goes from there to the next outlet, providing power in PARALLEL. That is equivalent to the daisy chaining of the power from coil to coil.
You really just want to remove and tape and protect the grounding (switched) wire at the coil if you wise the coil to be out of a circuit.
Without a load, connecting power to ground is a short, and shorts are bad.
