(Topic ID: 131421)
Bypass "coin door disable coil for tourney on 90's Bally
By hisokajp
8 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 8 years ago by hisokajp
    #1 8 years ago
    We are setting up some games for a tournament and we would like to bypass the coin door open safety that disable high voltage coil in case of stuck ball (during multi ball) so the flippers do not go dead when we open the door.
    I made it work with alligator clip to permanently close the link at the back of the switch even when opening the door but isn't there an easier way?
    #2 8 years ago
    Black electricians tape to hold it closed. Pull the wires and hook together to eliminate the switch. Don't open the door. Things like that.
    LTG : )™
    #3 8 years ago
    When I bought my IJ way back in 1997 it had a flipper rubber wrapped around the switch holding them closed.
    Works fine if you have any spare.
    #4 8 years ago
    remove the bracket from the coindoor pressing against this switch
    pull out the switch to the out position
    #5 8 years ago
    all good suggestion, let me check it out, thanks!
    This page was printed from https://pinside.com/pinball/forum/topic/bypass-coin-door-disable-coil-for-tourney-on-90s-bally and we tried optimising it for printing. Some page elements may have been deliberately hidden.
