(Topic ID: 249572)
Buzz sound when powering on Fire! game
By rlbohon3
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by rlbohon3
#1 4 years ago
My Fire! game makes a loud buzz sound through the speakers for about a 1/4 second once it is powered on, especially after it has been off for a while. If I turn it off then immediately turn it back on, it doesn't make the sound. It's as if there is a capacitor that's draining when it shouldn't or something not quite workign right after the game has had some time the "rest" with the power off. I've replaced all the caps on the power supply and sound board, but no other components. Any idea what else to look for or what could possibly be related? The game operates ok; it's just that this sound is a little annoying turning the game on and a bit concerning that something is failing (maybe leading to more trouble).
#2 4 years ago
Quoted from rlbohon3:
My Fire! game makes a loud buzz sound through the speakers.
Maybe it's the game's fire alarm going off. It is a hot title.
#3 4 years ago
I had a similar problem with my Fire! It ended up being a ground issue. I removed all the screws holding the various electronic boards in place, made sure they were clean and correctly tightened. A few boards were actually missing a few screws.
The sound went away. Not sure it this is your problem ... but hope it helps.
#4 4 years ago
Thanks for the tip on the ground. I got this game a couple months ago and haven’t done a lot with it yet other than the caps, a few LEDs I had on hand and new rectifiers/fuse mod. I’ll check for grounds. Btw, here is a video showing the buzz on startup:
#5 4 years ago
That buzz sounds different than the one I had. Mine continued to buzz the entire time the system was on and wasn’t as loud.
I would still check the grounds . . . If would be great if you were able to identify where the buzz originates. Personally I would disconnect/isolate the sound card and see if the buzz still occurs.
I hope the gang can help figure this one out.
#6 4 years ago
Quoted from RNajarian:
Good tip, will do. I've since noticed that it seems a little more inconsistent as to how much time it needs to be off to make the sound when powering on. I'll check out the grounds and try to isolate the sound card and see what happens.
$ 18.95
$ 3.00
Tools
Nezzy's Pinball Prints
$ 27.95
$ 19.99
$ 18.00
$ 29.99
$ 65.00
$ 95.00
Pinball Mod Co.
2,800 (OBO)
Bellefonte, PA
$ 170.00
Displays
Digipinball Shop
This page was printed from https://pinside.com/pinball/forum/topic/buzz-sound-when-powering-on-fire-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
