(Topic ID: 266936)
Busted transformer? No, line filter. Is it needed?
By Axl
1 year ago
  • 28 posts
  • 14 Pinsiders participating
  • Latest reply 1 year ago by mbwalker
#1 1 year ago
I just got a space time pinball. The game is tripping the house fuse (16A). I have a friend looking into it. He has checked the following:
Cable and socket is ok
Power button is ok
He disconnected all the fuses except the 8 amp.
The transformer looks dead.
Any helpful hints on what to try next?
F0102E0B-20B3-4B3F-BA00-9FF57C2BD051 (resized).jpegD5333C5A-DDA2-45C6-A00B-9D1E5534EA51 (resized).jpeg
#2 1 year ago
Quoted from Axl:
Easy to test with a voltmeter
#3 1 year ago
Your transformer could have a shorted winding, which is causing it to pull a ton of current...which causes the fuse or breaker to blow / trip.
If you dont have a solid background in electrical theory or electronics, this might be a hard one for you. DON'T keep plugging it in to the wall socket. Find someone with a variac or experience testing circuits.
If this were mine, I would disconnect the transformer primary [where AC wall connects] and supply a lower AC voltage with a variac and start measuring AC output. Or reverse feed the transformer secondaries with low voltages and see how things measure.
I'd Nerd out and use my impedance bridge too.
#4 1 year ago
Check your hot, neutral and ground from your power cord and make sure someone didn't tie something together incorrectly. Easy stuff first.
#5 1 year ago
Thank you for helpful tips, i will test it out more.
One thing i forgot to mention is that my friend buzz tested the transformer against a Sea Ray transformer without load, and he got no errors.
Sea Ray has the same transformer.
could the transformer still be working? it looks very dodgy.
Edit, scratch that, they are not the same transformer...
#6 1 year ago
In my experience transformers are rarely the problem unless someone physically damaged them which is usually very obvious. Yours has some aged paper insulation but that says nothing about it’s electrical condition.
Test, test, test but understand you are working with full line voltage.
#7 1 year ago
I wish I could remember what it's called but it's not the transformer. It's the silver box that the power cord goes to before the transformer.
#8 1 year ago
These short out and blow house breaker.
Edit just realized it's a em. Dont think em's have this. It's a line filter.
#9 1 year ago
You are in Norway, I think.
Has this game been used in your country before?
Could this be a 120 vs. 240 setup issue?
#10 1 year ago
Quoted from Gotemwill:
I agree. However, I have had a transformer with an open winding and another with a shorted winding. Both on the secondary side. Not pinball transformers. It happens.
#11 1 year ago
Quoted from RCA1:
The owner has had it for 35 years and used it on and off. Now that its not working anymore, he sold it.
#12 1 year ago
This is a '72 Bally Fireball schematic.....the transformer part # is E 122-95
#13 1 year ago
Hi all and thanks for your input!
I was the one who tested this for Axl. I have not worked much on EMs yet, but I am eager to learn!
To recap, the problem is that it blows the mains the instant I plug it in. I checked the power chord and the power switch to be ok. I checked the 8 amp line fuse to be ok. I unplugged all other fuses in the game, and although I might be wrong this should mean that I am testing the transformer without load. Power in, no power out. It still blows the mains. Once the mains blow, there is a whiff of burning smell coming from the transformer - I might be imagining this though, as I cannot trust my sense of smell anymore. I am old.
The transformer appears to be wired correctly. Norway is 220V, and the wires go to the correct lug on the transformer.
Since the mains blow instantly, I cannot test any output whatsoever. So I came up with the idea of testing the transformer for continuity. Looking at the attached schems, it seems to me that lugs 1,3 and 5 should have continuity. The same applies to 7 and 8. What puzzles me, however, is that ALL the mentioned lugs buzz. Is this how it should be? I would imagine that bank 1,3,5 would be separated from bank 7,8 - especially since the fuses in the game are removed. The lower lugs do not, however, buzz with the upper lugs 2,4,8,10 - which I guess is good news.
Am I doing it wrong? Is there an approach to test the transformer under the given conditions? I would prefer not removing it from the game.
#14 1 year ago
Are you getting a continuity reading across the two prongs of the plug? That's the most basic way to start looking...
#15 1 year ago
The schematic shows primary windings 1-3-5 and 7-9 separated, but the wiring instructions do not comply with that.
#16 1 year ago
Sounds crazy, but did you check your plug on the cord (where you plug it into the wall) to make sure it is wired correctly. I am assuming it has a 'screw on plug' and not a molded plastic plug.
If you ohm or meter a transformer, you are going to measure low resistances because it merely is a coil of wire from one side to the other (hot to neutral). Yes, there will be separation between the primary input and secondary output. You need to find a variac or impedance bridge to test this properly.
#17 1 year ago
If you do find that it is bad I have a spare out of a bally night rider.
#18 1 year ago
Does your mains still blow if you have the on/off toggle switch in the OFF position?
#19 1 year ago
Ait, found it! Seems this old line filter is shorted. I cut one wire at the on-off-switch and there was still a buzz when testing. What is the best way to replace this? Is there any modern equivalent?
A5D1059A-DE4D-4A4A-93F7-5A7FC673446F (resized).jpegC5E898F7-FBF8-4571-BCDD-5A4225995D75 (resized).jpeg
#20 1 year ago
I don't know export games (outside the USA), but that might be a filter someone added and not Bally. Others can confirm. Those line filters were / are used on solid state games. Inside are resistors and capacitors that can go bad.
You can order replacements from Farnell or DigiKey. Those are European suppliers. You just need to spec your AC voltage and current of the game. A 3 to 5 Amp filter would be plenty.
#21 1 year ago
The mystery box seems to be an "Radio Interference Filter" which I'm not sure is needed at all. Seems that it was just a requirement for German games at the time. Can I just remove it and connect the mains on either side without messing anything up?
#22 1 year ago
Quoted from Archieball:
Yes.
#23 1 year ago
I'd open up the filter and take a look at what's going. The filter is just an LC (inductor/capacitor) low pass filter. Maybe it has MOV in there too.
#24 1 year ago
I have removed the line filter for now. I am working on changing all the fuse holders before I fire it up.
#25 1 year ago
Quoted from Axl:
Hey Axl,
Mind opening up the EMI filter and shooting a few pictures to post so we can see what is going on? Curious minds (me) would like to know. No biggie if you are busy.
#26 1 year ago
Quoted from mbwalker:
I will try to open it up next time i am at the club. When i looked at it, it looked very sealed.
the game fires up and all is well! Now to chase out the gremlins.
thanks for all the help.
#27 1 year ago
Just a small update, the box is glued/welded shut.
B2A01C73-EDF6-4D2C-8988-FAAE70B767E8 (resized).jpeg74883AB6-A0C7-467A-AA08-6659735C0A7F (resized).jpeg16F9832F-0A7E-4AFE-9270-0D2724B3A162 (resized).jpeg
#28 1 year ago
Quoted from Axl:
Thanks for the post. Boy, they did button it up well!
