(Topic ID: 241142)
Burnt pop bumper coil - Firepower II
By aborup
  • 9 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by chad
#1 4 years ago
Hi everyone. I am a still pretty much a novice when it comes to repairing my pinball machine. I am OK with swapping out parts and soldering, but not very good at understanding how to test things or to do board-level stuff.
Here's my story:
Last week we had company over and got into a marathon pinball series. All of a sudden the room smelled like burnt electrical parts. Inspection showed that my top right pop bumper coil got blazing hot and the plunger was stuck down. I powered off the machine and removed the coil. SG1-23 850DC. I went online and ordered a replacement (SG-23 850DC), which came with a new sleeve and resistor/diode? (I think it is a diode.) I cleaned and steel-wooled the plunger and reinstalled the assembly. After installation, the solenoid still does not work. I put the machine in diagnostic mode and all solenoids fire except that one. I have a feeling that something else must be wrong - perhaps on the driver board? I do not have any test equipment other than a cheap digital multimeter.
Firepower II and Black Knight share the same MPU and driver boards (Williams System 7 I believe).
Any advice on next steps?
#2 4 years ago
Your driver transistor (TIP 102 can BE USED) and pre driver 2n4401 should be changed . The driver boards can be swapped.
#3 4 years ago
Just need to know which pop bumper it is and then you can locate the transistors.
#4 4 years ago
Update -
Thinking I was a genius, I decided to try to eliminate the possibility that the new coil was bad. I detached the red and black wires from one of the other pop bumpers and then jumped those wires to the new coil, thinking that that would make it fire if the coil was good. WRONG. Pop sound, burn smell and smoke came up from the right rear side of the driver board.
Now when I power the machine off and back on, it sounds funny and solenoid(s) fire instantly. Did I fry the driver board? Can I fix the board myself or should I buy a remanufactured one? Will that fix my problem or do I need to look at something else as well?
#5 4 years ago
Quoted from aborup:
Update -
Worst case you can send it out to Clive at Coinopcauldron.com
Not sure if Rob at lockwhenlit.com works on older games..
#6 4 years ago
My driver board has some burnt looking areas on it as shown here:
20190419_163051 (resized).jpg20190419_163051 (resized).jpg20190419_163125 (resized).jpg20190419_163125 (resized).jpg
#7 4 years ago
Very normal for those resistors to be discolored. They control feature lamps and get hot enough at times to unsolder themselves.
#8 4 years ago
Thanks for theme replies. If I replace the driver board completely, can I assume that everything should be working again?
#9 4 years ago
Yes, but replace the diodes on the 2 coils you have had issues with.
$ 1.00
Pinball Alley
$ 11.95
$ 12.50
RoyGBev Pinball
Tools
Pincoder Store
$ 22.50
$ 36.95
arcade-cabinets.com
$ 65.00
This page was printed from https://pinside.com/pinball/forum/topic/burnt-pop-bumper-coil-firepower-ii and we tried optimising it for printing. Some page elements may have been deliberately hidden.
