My STTNG had some GI issues, and when I traced the problem I eventually discovered that the connector that goes to J121 has a cooked pin 10. There is a lot of information on this board to glean information from, and it's clear that I need to replace the connector, but I still have a few questions. My apologies if this is beating a dead horse, but I couldn't dial in my searches to find what I needed.
1. What would have caused this? Is there something that I should be looking for? Everything else downstream from the connector looks great, as does the return pin at J121 pin 5. Can it just be age?
2. Can I test the power driver board somehow to determine whether or not I need to replace the header without removing it? It looks daunting. I'm up for it if I have to do it, but obviously would prefer not to unless it's necessary. The header itself looks good. It seems the prevailing opinion is to replace the header, but it doesn't hurt to ask
3. Does this happen fast or over time? If it's over time, how the hell did the guy who "shopped" this when I bought it not see it? If I were shopping something, I'd pull every one of those things and inspect them.
4. I assume that leaving that connector unplugged so I can play the game until I can get it fixed is acceptable, but figured I'd make sure. It looks to be all GI, and I turned the game on for a minute to check. It's dark, and it looks weird without jets and shields lit, but otherwise seems ok.
Thanks,
Gabe
