Quoted from burningman:Also, anyone know how to tighten up a light socket? I have a socket on one of my Ramp Board Signs that is troublesome. btw, its the socket, not the bulb...the bulb is tight
burningman:
the 555 twist-in socket is loose against the pc board for the one of the signpost bulbs?
if so, the following should help you out:
- remove the bulb and socket in question
- using a toothpick or a small pair of needle-nosed pliers, carefully bend the 2 contacts of the socket outward so that more tension is created when you re-insert and twist the socket to lock it in place.
if that doesn't work, you can tackle it the harder way:
- remove the wired connector to the board and unscrew it from the stand up post
- next, remove the bulb in question and it's socket
- heat up and re-flow the 2 solder covered curved connect areas that the bulb socket contacts press against.
note: if that doesn't work, using leaded solder (you want to use the same type which is already there), heat up and flow in additional to the 2 solder covered curved surfaces that the contacts from the bulb socket make connection with when you twist and lock the socket in place.
note: you want to flow enough so that the solder pools and solidifies to a pair of arcs that are about 1/32" raised from the surface of the pc board
- re-assemble
(changing out the bulbs numerous times will cause the solder arcs to wear down ever so slightly [the solder is much softer than the copper contacts on the bulb sockets]. in addition, the surface of the solder can become oxidized causing a poor connection to the 2 contacts of the bulb socket.
