I held right flipper on Bally KISS for 20-30 seconds and burned out the solenoid. In the pix, the left orange wire run in the wire harness, the center grey runs to the EOS switch, the right grey wire runs to the EOS switch, and the right brown wire runs to the harness. The two grey wires are spliced to the wires connected to the solenoid with masking tape....! The EOS switch is always closed and opens when solenoid is activated and is 2-leafed, not 3. I assume the EOS is correct for this model. I also included pix of the solenoid as it does not match the left flipper.
