(Topic ID: 115983)
Bumpy playfield Lights not flush
By taxi_for_one
5 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by taxi_for_one
#1 5 years ago
Good morning.. Just bought a beaten up Hi Speed for restoration
Main problem appears to be condition of playfield..
Some of the lights are sticking up above the playfield surface maybe 1/16th".
What would be the correct way to get them to sit back down flush with the PF surface.
Thanks very much..
#2 5 years ago
Heat from the underside with a blowdryer and press down till flush.
#4 5 years ago
Sorry is that like a regular hairdryer? Tried it for 5 minutes but nothings moving yet.. Thanks
#5 5 years ago
A heat gun will get a little hotter than your traditional hair dryer. At 500-1000 degrees, you probably wouldn't have any hair left. Anyhow, here's a link to one that might work for you:
http://www.harborfreight.com/1500-watt-dual-temperature-heat-gun-572-1112-96289.html
Hope this helps,
Ryan Claytor
Elephant Eater Comics
www.ElephantEater.com
#6 5 years ago
Thanks gentlemen.. Really appreciate the heads up..
#7 5 years ago
Be very, very careful with that heat gun.
It will melt mylar, melt the insert or set things on fire if you are not careful.
RussMyers
#8 5 years ago
Thanks Russ...
$ 17.00
PinWoofer
$ 54.99
$ 29.99
$ 109.00
Cabinet Parts
Tilted Pinball
Metal-Mods
$ 164.99
PinballBulbs
$ 9.00
$ 19.99
Gweem's Mods
