(Topic ID: 166455)
Bulletproofing save me from a fire? And.. what now?!
By PA28steve
7 years ago
#1 7 years ago
I have an old Black knight machine - The kind with the system 6 power system still.. As part of preventative maintenance, I added Inkochnito's kit to fuse my full wave rectifiers (http://www.inkochnito.nl/). Everything was great, until I just turned on the machine, and I couldn't get it to play.. I had been having trouble with the start button switch input, which is what got me to start the bulletproof project in the first place, and so I immediately thought it was just not registering my start game, but then after running switch tests and realizing the switches were all OK, I noticed that it actually WAS starting, but that NONE of my solonoids were working at all. Additionally, the flippers were dead. Very long story short, I traced it back to a bad fuse on the newly added board.
The purpose of the fuses as I understand is primarily to prevent a fire in case of a shorted bridge rectifier. I have tested the rectifier on the add-on board, and it seems fine, so I'm curious about where else to consider looking for a root cause..
I haven't replaced the fuse yet, so I dont know if it was a one time occurrence, or if it's going to blow right away when I fix it, but I'm concerned that perhaps the other bulletproofing measures may have changed the load on those solenoids, and maybe 8 amps isn't the proper size for this fuse? I have replaced the driver transistors and the associated high wattage resistors with the jumpers as otherwise discussed on the bulletproofing thread, and I'm wondering if that might make my system take more amps than a "standard" configuration.
I'm just about to go out to radio shack and buy a handful of fuses but I was curious if I should try a higher amperage one? Normally I wouldnt consider replacing a fuse with a higher value one, especially as someone who had a house fire in 2014, but since these fuses are add-on protection that weren't even in the original game, I figure there's enough wiggle room to ask what the 8 amp value is based on?
Any opinions?
Steve
#2 7 years ago
Quoted from PA28steve:
No! Never. That's called "overfusing".
A fuse is supposed to be the weak link that fails when there is a problem in order to protect all the other components behind it. It is a ceiling for the current being drawn on that particular circuit. If the draw is too high for that particular circuit, it can damage things, so the idea is that the fuse will blow before damage occurs.
I keep at least 5 (but usually 10) of each fuse on hand. I also have a few different push button circuit breakers for diagnosing a fuse that keeps blowing (so that I don't keep wasting fuses).
Fuses blow for all sorts of reasons. Sometimes because the amperage draw is too high. Sometimes just because the fuse is flawed in some way. Usually, if a fuse blows without any prior history of blowing, just replace it and see what happens. If it doesn't blow, there might not even be a problem. If it does blow a second time, then it's time to investigate further.
#3 7 years ago
Assuming things are wired and fused properly(read this http://home.kpn.nl/p.koch3/Inkochnito_Bridge_Board.pdf ), if that fuse blows immediately on power up. The bridge rectifier is shorted.
Take your DMM. Set it to diode test.
Red lead on bridge negative lug (i know it seems backwards) and probe the AC lugs (wavy lines). You should see 0.4v to 0.6v. If 0.00 is shown, that is why the fuse is blowing.
Repeat procedure for other half of the bridge. Set the black lead on positive lug. Red lead probe the AC lugs. Again. 0.4v to 0.6v.
If the bridge is OK but the fuse is blowing, you have some kind of wiring issue i'd assume. The 2.5a slow blow fuse on the power board is much lower rated value, it will blow if something on the rectified side is shorted/pulling to much current.
#4 7 years ago
I wonder if these could be useful in our hobby?
ebay.com link: 20pcs RUEF300 30V 3A UF300 PPTC PolySwitch Resettable Fuse
They have other values, I might try some and solder them across a blown fuse.
#5 7 years ago
When you installed the fuse, did the fuse blow the first time you powered the machine on? Or did the fuse blow after a few games/days?
Depending on how much metal has attached itself to the inside of the fuse (i.e. how black the glass is or not) can tell you if it was a violent short circuit blow, or a mild over current blow.
#6 7 years ago
Quoted from Chuck_Sherman:
ebay.com link » 20pcs Ruef300 30v 3a Uf300 Pptc Polyswitch Resettable Fuse
I think the biggest issue would be that you want total isolation in HV applications when a component fails. Current leakage can occur when a PPTC goes into high resistance on a failure. That current leakage could then potentially damage other areas. Probably best to just have a clean break with a traditional fuse.
These might work in the lower voltage areas though. I still would feel a little nervous trying it out though. I like the idea of a clean break.
These are good for sealed up low voltage modern electronics that were designed with their use in mind, like computer components running on USB or something. I couldn't see using these ending well in a pin. Although I've never used these in any designs, so maybe someone that has experience with these can chime in.
#7 7 years ago
Thanks for all the responses.. @ForceFlow, I would typically be as adamant as you, regarding not increasing fuse values, but since there was no fuse there in the first place, my question was whether someone did some calculations to come up with the 8 amp, since that wasn't an original design value..
I had tested the bridge, and it was fine.. and, although it doesnt get much use, it's been 6 months or so since I installed the fuse kit, and it's always worked fine. I can't remember that it failed, so it makes me think someone who was over must have been playing it, and it broke, and they just walked away without telling me, and later, I just shut it off..
After posting earlier, I replaced the fuse with an identical 8a slow blow, and it came right up.. I played for 30 minutes or so, with no problem (other than my terrible rusty pinball skills) but the power light on the board that indicates the voltage is good would dim whenever a flipper or solenoid fires. I never looked before, so I dont know if that's new or not..
Anyway, if it's not unusual for the occasional fuse to blow, perhaps I'll just consider myself lucky that this is the first time on this machine, and just keep the spares handy (I bought 8). And, if something did short hard, then I'm really glad I installed the fused bridge board, because maybe it would have started a fire while unattended, whenever it happened!!
Thanks!!
#8 7 years ago
I have no idea. But it is easy to measure anything under 10a with a multimeter yourself to see what the load is while idle and while under stress. Although, it is usually best to do this on a game that is known to be operating correctly.
I had to measure and specify a new fuse value for an obscure game that was obviously overfused from the factory on the solenoid circuit. The result of the factory spec was that locked coils would not blow a fuse since it was rated too high, which would have caused damage if the coil was left on like that for too long.
#9 7 years ago
I purchased a couple of these fuse circuit breakers from Bob Roberts for my arcades. They work great for identifying problems without going through a box of fuses.
http://www.therealbobroberts.net/cirbreaker.html
4 weeks later
#10 7 years ago
I've taken the fuse value from the advise on Clay's guide (now gone) to add an 8A SB fuse in front of the bridge rectifiers.
Since this is a Black Knight it could use a higher fuse value.
The schematics for the Power Supply calls for a 20A fuse for the flippers en magnets!!!
This is WAY higher than the 8A SB.
Maybe with some trial and error we can conclude that a higher value would be needed with Black Knight.
Just be sure that all coils are good and working properly before you put in a higher fuse on the Bridge Board.
I think you can easy put in a 10A or 12A fuse.
The coils are only pulsed for a short time and the fuse gets time to cool down.
Don't worry about the rectifiers, they can handle put to 30A.
Each magnet is fused by an 8A fuse (see schematics).
I'm not sure about the flippers though.
They might have a fuse under the playfield, but if there isn't a fuse, there is only the 20A fuse on the power supply.
Maybe adding a seperate fuse for the flippers would be a good idea.
I had tested the bridge, and it was fine.. and, although it doesnt get much use, it's been 6 months or so since I installed the fuse kit, and it's always worked fine. I can't remember that it failed, so it makes me think someone who was over must have been playing it, and it broke, and they just walked away without telling me, and later, I just shut it off...
This might very well be the case.
If you activate both magnets AND hold in the flipper buttons, that would most likely cause the fuse to blow!
After posting earlier, I replaced the fuse with an identical 8a slow blow, and it came right up.. I played for 30 minutes or so, with no problem (other than my terrible rusty pinball skills) but the power light on the board that indicates the voltage is good would dim whenever a flipper or solenoid fires. I never looked before, so I dont know if that's new or not...
The dimming of the led is normal.
When there is a power draw, the voltage drops a bit and thus dimming the led.
Thanks!!
Thanks for putting your trust in my Bridge Board.
Peter
www.inkochnito.nl
5 months later
#11 7 years ago
Did this ever get resolved? Considering adding one of those to my Black Knight.
Tim
#12 7 years ago
Quoted from Thorvald:
Tim
I never got any word back.
Go ahead and install my Bridge Board.
You can't go wroung, only safer.
If you run into trouble, just let me know.
Peter
www.inkochnito.nl
Hookedonpinball.com
Westjordan, UT
$ 12.50
RoyGBev Pinball
$ 18.95
$ 160.00
Sparky Pinball
2,500 (OBO)
Vista, CA
$ 1,059.00
$ 69.00
Pinball Pimp
$ 17.00
Metal-Mods
$ 959.00
Newcastle, OK
$ 95.00
Pinball Mod Co.
$ 53.95
$ 69.00
Pinball Pimp
Metal-Mods
This page was printed from https://pinside.com/pinball/forum/topic/bulletproofing-save-me-from-a-fire-and-what-now and we tried optimising it for printing. Some page elements may have been deliberately hidden.
