I am converting my Genesis over to led lighting and I am having an issue where some of the controlled lamps go out. I replace them with another bulb, fire up the machine and the bulb will flash during attract mode and then burn out...literally (checked continuity on the bulb). The problem first started on the body parts bulbs at the back of the play field but I also have the problem on the ABC lights and the green ramp entrance light. Does this usually mean there is too much voltage? I can measure the sockets when the machine is running. I am assuming one probe on the socket an another on ground?
