Can any one tell me what types of bulbs these are. It looks like mostly 44/47 but their are also 2 bigger sizes--- Its A Bally Broadway And any Idea where to get 2 new side rail locks ???
Your white board number lamps would be 17 V.
I use 1464 lamps.
The 44 lamp, I use them, draw a little more current, but have
10 X the life of a 47 lamp, and, on average, are a bit cheaper!
I use 55 lamps(the bigger ones)on my play field, they are bright, but since, my home game
is on only an hour or so a day, I like the bright look!!!
Get a good tool for removing the lamps, you will thank yourself!!
Terry K
I forget the number of the larger bulb - it is essentially a flash lamp package, but rated at 6V (for doubled scores).
Terry is correct about the 1464s behind the bingo card.
The siderail locks - you're out of luck! You'll have to find from a parted game. I've never found anyone that makes new screw locks like those.
I just edited my post. The bigger lamps could be 55 lamps.
I also use 455(flasher) lamps in some spots, they LOOK the same
as a 55 lamp.
This seller on eBay has them, I bought loads (just in case) for myself here in the UK
He calls himself mffe $24 for four locks. They are original. Search for bally locks. He has 6 left at this moment!!!!!
Edited
Actually he has more, type A and type B, he's been selling these for years, where the hell does he get them all from??
I'm a terrible hoarder maybe I should get some more, what do you think?
1458 lamps will do if 1464 are hard to find
The 1458 lamp is a 20V lamp.
The 1464 lamp is a 22V lamp.
They both draw .25 A(250 mA)
They both have a rating of 250 H.
The 1464 seems to be a bit cheaper
because, I believe, they are harder to find
This page was printed from https://pinside.com/pinball/forum/topic/bulbs-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
