I have started a separate thread on pinball lamp driver to enlist input on choices for building your own lamp driver board.
I have another thread on my arduino conversion of Close Encounters machine.
Before putting solder to board I am pausing to enlist input of others.
My original plan was this.
Create a separate board the is controlled by i2c or spi connection. Allow 32 to 64 output lamp/led controls. Switch will basically be a low side switch. No pwn controlled output.
A bank of 4 or 8 shift registers to feed 4 or 8 darlington unl2803.
Traditional circuits use fets or mosfets as opposed to using an array bank approach.
Another issue to consider is max current draw and heat stress on board.
Any comments or suggestions on building your own lamp driver board ?
