Hello all,
I am a new member here and this is my first post. I have been a member of klov for a few years now and have recently sold off most of my video game collection to consentrate more on pinballs.
Here is what has been done to buck so far by me. I have installed a new xpin power supply in the back box. I have removed the battery from the mpu and added a remote one. I have done a few of the ground modifications. All fuses are good and the correct size, all coils check good, the edge connectors are not new, but are making good contact. I have inspected every one of them. I plan to re pin them, but not yet.
Here is what its doing. When the game is turned on I get general illumination, 5 seconds later the tilt and game over relays engauge and then disengauge, but I get no displays and it seems like the game does not boot. I dont think it was booting because if I hit start, or add a credit nothing happens. There is one bulb blinking behind "high score to date" all the others are lit solid. If the game has been powered up for a minute or two I think its in attract mode because some sounds will go off then stop. I checked the x pin power supply and it is not getting the +60v needed to power the displays. I then plunged below the play field and tested the bridge rectifiers. The one on the left (cpu lamp bridge) tested .45 across all 3 connections. I had set my meter to diode setting and put my red lead on the ground and used the black lead to test the other 3 connections. I then tested the other one (Coil bridge) the same way. There was only one lead that read weaker than the rest. Two of them read .45, the weak one read .14. Does this mean I have found the problem? I have not tested the small transformer voltages yet, because I didnt know what the voltages were supposed to be. Pinrepair.com has realy helped me in the disagnosing of this machine but I figured I would reach out here and see if I can get any other directions to go.
Thank you in advance for the help,
Austin
P.S. If needed I can provie pictures and a short video of what the machine is doing.
