Quoted from CactusJack:Buccaneer has a liberal/conservative adjustment for spin and spot. However, in 3 ball mode,it is lit all the time until you complete the entire sequence and relay 12B trips.
Otherwise, in 5 ball mode, the position will determine how many or which of the 3 positions the score motor can sit at to light it. I think in the liberal setting (all the way over) it will light all the time in 5 ball mode also.
The Spin and Spot lamp has a 75 ohm 10 watt Ceramic resistor in line with it and I believe it is sized for a #47 lamp (not a #44). If the 47 is too bright, then use a 44. If the 44 is dim, use a 47. If it doesn't light, check for 75 ohms across the resistor. And, WHATEVER YOU DO, do not install a 44/47 equiv. LED in it as it will burn up (getting 25VAC). To use an LED, you would have to replace the ceramic resistor with something like 1000 ohms (based on 20ma LED current draw).
Just an update to this narco thread =)
I have a Ship Ahoy that I had replaced some bulbs with out of the box 44's and it of course the Spin and Spot lasted a day since it was running higher voltage. Then I installed a red LED and it last about 2 minutes before frying! I did some research which lead me to this this thread.
Busting out the digital voltmeter with the correct 47 bulb installed 7.5 volts was measured, clearly over the bulbs 6 volt rating. I checked the resistance of the resistor and it was 75 ohms. So I ordered a pack of 125 ohm ceramic 10 watt resistors and installed one tonight.
I almost ordered a 100 ohm too and wish I did, but lets move along..
With the 125 ohm resistor installed with the 47 bulb I now have 3.9 volts indicated. With a 44 bulb installed, back up to 7.5 volts.
I'm going to leave well enough alone and keep the 47 bulb in running at 3.9 volts. It is bright enough to see clearly, though looks a touch dark after the "oh my god I'm going to burn at any second!" bulbs running at 7.5 volts.
100 ohm with a 47 bulb would be just about right I reckon.
Hope this has been of some help.
Edit- FYI the two Wow lamps are also at 7.5 volts measured but since they don't turn on as much as the Spin and Spot light I left them alone.
