(Topic ID: 5006)
Bubbling mylar on purchase prospects
By wizzardz
8 years ago
  • 14 posts
  • 11 Pinsiders participating
  • Latest reply 8 years ago by JWS64
    #1 8 years ago
    While I tend to be an old school pin guy (EMs and early SS), I have been looking at some newer pins. A couple that have peaked my interest also report bubbling mylar. I’m assuming I could do something to mitigate the bubbling (pin poke and heat to reaffix, etc) until such time as I decide to strip the pf. However, the prospect of having to strip a complete pf of mylar – even if I kick the can down the road a bit – is something I’d at least need to plan for.
    While each prospect would also likely need to be otherwise shopped to the extent of replacing rubber and perhaps plastics (I’d likely do a none pf strip shop anyways), my concern is how much of a hit on price would be appropriate for “minor” mylar bubbling. The price guide on pinside is right at the asking price in each case, but I’m not sure what sort of condition is associated with the price guide (i.e., price guide = avg condition, great condition, etc).
    I’m assuming the mylar covering the entire pf is something done at the factory (EATPM and WW in this case). How common is it for bubbling, and what is/are the common causes? Is there any expectation that a repair to bubbling mylar (whether cut and replace, or poke and heat) would be an “acceptable” repair in that it wouldn’t look like cr@p or affect play?
    #2 8 years ago
    Thats one tough question to answer wizzardz
    It would have to be case by case example and if the seller is willing to see your point of view?
    I'm sure you may get the old - take it or leave it from the seller as well as a price jump the next day if it's for sale on line like C-List.
    It's the chance you take a few dollars off or a door slammed in your face
    #3 8 years ago
    Quoted from wizzardz:
    Don't assume that you can easily repair it. The bubbling is normally because the layer of glue has either lost contact with the mylar or with the play field and re-sticking it isn't something that I have heard of.
    This problem often happens on painted play fields (pre-diamond coat) because of heat from the lamps. Some times it's best to either accept it or remove the mylar and risk damaging the play field. It may also be a symptom or raised inserts due to the heat and age.
    Very common in games before and including Funhouse and BOP.
    You could view it's presence as a good thing as many of these games would be worn down to the wood if it wasn't for the presence of the mylar. If you can remove it the playfield is often like new below. Having had a disaster myself (after several previous successes) I wouldn't remove it unless it was pretty bad.
    #4 8 years ago
    From what I've seen, bubbling Mylar on System 11 playfields like Elvira is pretty common. My BOP has it as does my Whirlwind. On BOP, there are no lifted inserts, just the unstuck Mylar in places. Whirlwind has some lifted inserts in addition to some general bubbling. Not much you can do about it as others have said because the glue isn't good any more. So you either live with it, or bite the bullet and remove the Mylar and be ready for everything that comes along with doing that.
    #5 8 years ago
    I used to be afraid to pull the mylar, but now its just part of refurbing a pin to me. Practice on some less valuable games first, but once you do it a few times its pretty easy.
    #6 8 years ago
    If there's one thing I do know, it is this...I will never buy and own a pin that
    has mylar on it, and will never go near a pin needing mylar removed from it.
    I don't do mylar.
    #7 8 years ago
    I like removing it and on games that the playfield is nice underneath. Remove, clean, touch up, new insert decals if needed and clearcoat. Makes them look really nice.
    #8 8 years ago
    Whole playfield mylared in 1979... I think it does it's job when the pin is taken care of.. enough said.
    #9 8 years ago
    If the playfield is diamond coated then removing the mylar shouldn't be an issue. Removing it from painted PFs can possibly cause more damage than it is worth.
    #10 8 years ago
    Quoted from JWS64:
    I don't do mylar.
    Have to disagree with you on this one.....If the inserts arent raised & the mylar was factory then after you remove it you will have almost a brand new playing surface. Ive removed mylar may times & was blown away with how nice the play field was under the mylar.
    #11 8 years ago
    I guess this begs the question as to which pf have diamond plate? Do all machines after a certain time have dp, or was it like a distributor option (dp, mylar, or both)?
    It sounds like I don't necessarily want to run from any machine with bubbling mylar field...but need to consider it due for a peel in the short term.
    #12 8 years ago
    DP playfields are standard on williams machines from t2 on. Before t2 there were some machine which had short runs of DP and another process (name escapes me). For example there are a small number of diners and riverboats with dp playfields.
    As for pulling mylar it depends on the game. The freeze spray method works best but then you have to get all the glue off the pf. I do not like doing sega playfields as the last one I did the mylar pulled off inserts even with the freeze spray.
    #13 8 years ago
    This article gives a history of playfield clearcoating (about 2/3 down the page, What is Diamond Plate on a playfield):
    http://www.flippers.be/pinball_playfields.html
    #14 8 years ago
    Quoted from smassa:
    It's ok if you have a different opinion than mine. My personal preference is no mylar. Removing it, and having damage underneath is something I'd rather not to have to deal with.
    IF it was a pin as nice as Mystic's, and it was a pin that was on my "must buy/must have" list I'm sure I'd be looking over the playfield very closely IF I was going to buy it on the spot.
    Different strokes for different folks
    $ 189.99
    PinballBulbs
    $ 9.99
    $ 84.95
    $ 24.99
    Lee's Parts
    $ 49.95
    pinballmod
    Magazines/books
    The Flipper Room
    $ 8,999.00
    Classic Game Rooms
    Apparel - Unisex
    Pinball Wheezer
    $ 149.00
    Metal-Mods
    $ 38.00
    $ 45.00
    $ 7.49
    Yorktown Parts and Equip
    $ 36.99
    $ 23.25
    The MOD Couple
    $ 5,799.00
    Classic Game Rooms
    $ 999.00
    $ 27.99
    $ 28.00
    PinWorlds
    $ 149.00
    Sparky Pinball
    $ 5,999.00
    Great American Pinball
    $ 69.00
    Id Rather Play Pinball
