(Topic ID: 274916)
Stern Batman D. Knight Turntable problems...
By Flippermatt
    #1 3 years ago
    Hi.
    I cannot get my turntables to behave properly. I removed them in order to change the flashers underneath then put everything back together but obviously did something wrong..
    Where is the darn start position for both tables ? The manual makes no mention about it.
    Enclosed are two pics... I assume the spring should go through the hole in the bottom turntable, or not ? If this is done then it will not spin correctly. You can hear the motor trying to turn but obviously one of the hooks ist then at end position and won't go further.. However I try the constellations, both tables are out of sync when spinning and line up totally offset..
    Is the spring in the pic already in a wrong position default ? Should it be turned, it's connected directly on the motor.
    Is the spring's purpose only to push the bottom turntable upwards in order to lessen the friction or does it play a role grabbing any of the hooks when inserted through the hole of the base ?
    Pls any help or guidance is highly appreciated.
    Matt
    20200810_165715 (resized).jpg20200810_165715 (resized).jpg20200810_165732 (resized).jpg20200810_165732 (resized).jpg
    #2 3 years ago
    I’m sure the user manual has a detailed layered drawing/picture of where everything goes.
    #3 3 years ago
    Quoted from Rarehero:
    This is all I can find... Doesn't really show the starting positions of both tables OR if the bottom spring should go through the small hole or not of the bottom table. Can you make it out ?
    15970782251738839535348039849496 (resized).jpg15970782251738839535348039849496 (resized).jpg
    This page was printed from https://pinside.com/pinball/forum/topic/btdk-turn-table-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
