Hi All,
I have a switch matrix issue I can't seem to solve-any ideas would be greatly appreciated. Initially, I had an issue with switch 55-it was reading as always open causing the wire ramp popper to fire repeatedly. I confirmed that there was no issue with the optos, and that there were no visible wiring issues. Eventually I began receiving error messages for switches 15, 35, 55, and 65. I have done the following:
Inspected the CPU board for any corrosion-none visible.
Checked all connections on the CPU board and they look solid-(reflowed the solder on the lm339 at u19 to be sure).
Checked the ribbon cable from the main power driver to the cpu board.
Detached and reseated all connectors to the 10 opto board and the CPU board. Also inspected the pins and connectors for corrosion.
Replaced Fuse 115
Tested the switches as outlined here http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Switch_Matrix_Problems All switches closed properly and there were no issues with multiple switches firing.
Removed and visually inspected the 10 opto board (which is a homepin replacement board) . . . no apparent issues.
Checked voltages on power driver board at test points 1-4. All were normal.
The only thing that seems a little odd is that led 3 on the power driver board (near f116) is very dim, however it lights fully when the wire ramp popper associated with switch 55 fires. Is this normal?
I'm new to this, so I'm sure there are few things I'm missing. Anything else I should be looking for or tests I should be running? Thanks!
Z
