(Topic ID: 245328)
BSD restoration - a real project
By Pinballer73
9 months ago
  • 267 posts
  • 33 Pinsiders participating
  • Latest reply 5 months ago by pintechev
  • Topic is favorited by 28 Pinsiders
There have been 356 images uploaded to this topic. (View topic image gallery).
There are 267 posts in this topic. You are on page 5 of 6.
#201 8 months ago
I have well over a hundred photos showing all sections under the playfield, if anyone needs to see anything in particular I should have a photo to help you.
#202 8 months ago
Wiring harness all clean and ready for inspection, and where necessary plugs, switches, lamp holders and targets replaced.
#203 8 months ago
Lots of little bits and pieces done today, but nothing really worth adding to the thread other than to show the shooter lane clean-up. This is the before photo, with the ground in grime after a thorough clean of the playfield some weeks back.
#204 8 months ago
Sanded back to remove the stain, looks much better. This had the effect of making the grove slightly deeper and longer. I could have removed more material, however sometimes the enemy of a better result is actually worse, so I decided to stop there. As it stands, I may have to adjust the auto ball plunger mech during the rebuild to align it with the centre of the ball. 20190806_111200 (resized).jpg
#205 8 months ago
First and second coats of clear.
#207 8 months ago
A light sand and a third coat. The first two just sealed the surface as most of it gets absorbed by the timber. Still needs a very light sand then polish to finish the surface for use.
It's not to the standard of a HEP restore, but I'm happy with the result.
#208 8 months ago
This is the product I used, available in most hardware stores here in Australia.
#209 8 months ago
Quoted from Daditude:
Amazing thread! Keep it up!!
Thanks! There's been times when I've questioned my sanity! Small wins like this make it worthwhile.
#210 8 months ago
Playfield slide hinges and locking bar mechanism cleaned, ready to reinstall when the time comes.
#211 8 months ago
Whilst it doesn't justify the expense to replace it and it functions perfectly. Can someone explain how it's possible to break this assembly?? Surely excessive force was used?
#212 8 months ago
Great thread mate. Strange but it makes me want to start cleaning pinball parts.
#213 8 months ago
Quoted from Drac:
Thanks. Yes, it's strange but satisfying slowly bringing a game back to life. I think I enjoy it as much as playing the games in a different way.
#214 8 months ago
Quoted from Drac:
Come to my house and i will give you a towel.
#215 7 months ago
My paid job has been slowing down progress lately. Finished the last of the work on the bare playfield today. With the t-nuts removed, I took the opportunity to freshen up the rear of the playfield by giving it a light sand to remove the vast majority of the grime stains. Didn't go too hard, just two laps with the random orbital sander, 120 grit, then 240.
#216 7 months ago
Quoted from Pinballer73:
My paid job has been slowing down progress lately. Finished the last of the work on the bare playfield today. With the t-nuts removed, I took the opportunity to freshen up the rear of the playfield by giving it a light sand to room the vast majority of the grime stains. Didn't go too hard, just two laps with the random orbital sander, 120 grit, then 240.[quoted image]
I'm glad to see you are making progress. I was getting worried.
#217 7 months ago
Then cleaned the rear of each insert. Should look good when lit.
#218 7 months ago
T-nuts installed, most were cleaned up and reused, some were in bad shape, with 8 being replaced.
#219 7 months ago
Ready to go back onto the rotisserie.
#220 7 months ago
After two coats of carnauba wax applied and buffed. Hope to start the process of putting it all back together tomorrow morning.
#221 7 months ago
Yeah me too!
#222 7 months ago
Started the rebuild this afternoon. Not a lot done, but enough to see some progress. It's pleasing to start reassembling after all this time.
#223 7 months ago
looking great
3 weeks later
#224 6 months ago
Recently I haven't made as much progress as I would have liked. Work and other distractions have kept me from the project. Today I had some time to myself, so I switched the radio on and got some work done. Enjoyed every minute of it.
#225 6 months ago
Cable harness supports and other under playfield hardware mounted.
#226 6 months ago
Harness loaded into the cable support brackets. The yellow cable ties helped locate the harness along with the wire memory.
20190913_162923 (resized).jpg20190913_162938 (resized).jpg20190913_162901 (resized).jpg
#227 6 months ago
All the wire rollover microswitches are now mounted and lamp boards plugged in. Will replace some selected lamp holders next before mounting the many game mechs and soldering the wires to each coil as well as replacing all the standup targets. Slowly coming together and I hope to get a few consecutive days work done in the very near future.
#228 6 months ago
Looking great, love a good Williams restore
#229 6 months ago
Coming together nicely!!
#230 6 months ago
Thank you. Back to it today and spent most of it replacing lamp sockets.
#231 6 months ago
And then replaced the incorrect standup targets that had copped a fair floggin...
#232 6 months ago
Nice new ones installed ready for action, along with new pop bumper hardware.
#233 6 months ago
Doesn't look like much has progressed when comparing these playfield photos to others above. Although, a lot has now been screwed into place, from the new lamp holders, playfield rollover microswitches, pop bumper hardware, standup targets and other miscellaneous parts. All very time consuming but not very evident when comparing photos.
**Please note that the metal ball guide to the left of the mystery hole is incorrectly installed 180 degrees. Refer to post #260 for the correct orientation of this part.
#234 6 months ago
Next job is to replace the slingshot switches, as the switch blades on the existing ones are all bent and twisted. After that, the rusty offset lamp holders need replacing as shown below.
Once this is done I can start repopulating the underside of playfield with all the mechs. Progress should then be a bit quicker and more satisfying.20190924_162313 (resized).jpg
#235 6 months ago
looking good
#236 6 months ago
its getting there! keep up the good work
#237 6 months ago
Thank you. Managed to get some more time into the rebuild today. All the metal lamp sockets are now replaced and most of the rebuilt mechs are now installed. Hope to get some more done tomorrow morning.
20190926_165129 (resized).jpg20190926_164923 (resized).jpg20190926_164930 (resized).jpg20190926_165113 (resized).jpg
#238 6 months ago
This mech had been somewhat stripped for parts, with the entire opto assemblies including their wiring harness and mounting screws removed. It's now assembled with some new parts and ready to go onto the playfield.
20191003_140103 (resized).jpg20191003_140125 (resized).jpg20191003_140145 (resized).jpg20191003_140206 (resized).jpg
#239 6 months ago
Lots done under the playfield, with the pop bumper lamp sockets installed and just about all the mechs in place and LEDs loaded into the twist sockets.
20191003_140301 (resized).jpg20191003_135753 (resized).jpg20191003_135748 (resized).jpg
#240 6 months ago
Plenty of solder work to come with all the coils, a few switches and the pop bumper lamp sockets to be connected to the wiring harness. Then a tidy up of the wiring loom.
#241 6 months ago
Lots done under the playfield, with the pop bumper lamp sockets installed and just about all the mechs in place and globes loaded into the twist sockets.
[quoted image][quoted image][quoted image][quoted image][quoted image]
Looking pretty clean!!
#242 6 months ago
Once all that work is done, I'll continue on with the topside rebuild.
#243 6 months ago
Yes, it's incredible how filthy these games get over the years.
#244 6 months ago
As I mentioned at the start of this thread, I bought the game as a project with a number of parts missing. Using the manual and the Pinball Life Williams/Bally parts index, I've been able to identify what was missing and search for what I needed.
An example of this was the Mist magnet assembly. This was all that came with the game, laying in the bottom of the cabinet.
The gearbox, motor, support brackets and microswitches were all missing.
#245 6 months ago
I was lucky enough to find these parts from a parted out game. Just missing one microswitch actuator.
#246 6 months ago
All stripped down, cleaned and ready to reassmble. In this photo I've already reassembled the drive shaft.
#247 6 months ago
Back together and ready to attend to the wiring hacks, install new cinnector pins and molex connectors.
#248 6 months ago
Forgot to take more photos until I had it installed on the playfield with new wiring to the motor.
#249 6 months ago
The next job was to strip each wire, tin and solder to each and every coil, a number of switches and solder lugs throughout the playfield. Only a few left to go, In particular the pop bumper spoon switches. The underplayfield rebuild is almost complete.
20191006_211101 (resized).jpg20191006_142038 (resized).jpg20191006_142034 (resized).jpg20191006_211117 (resized).jpg
#250 6 months ago
Last job for the day was to align the shooter lane lift ramp and install the auto plunger coil mech. Still have to replace that lift ramp flap and install the outhole kicker mech.
$ 11.00
$ 49.95
Pin Stadium Pinball LEDs
