The old saying is that you fix one thing you break two. I tore down my BSD to clean and put some LED lighting in the machine. The myst was working great before the teardown. Now, all that happens is the ball falls out of the right trap and straight down the playfield. The motor moves the magnet under the playfield and you can see the LED showing underneath as it moves from right to left. The magnet doesn't seem to be powering up. (My guess as I attempted to follow it with another ball on the playfield)
Questions:
Could this be an issue with the opto sensor?
Could I have detached a wire/connector from the magnet while changing bulbs underneath the playfield?(Like at J2 1 or 5)
How much power is being sent to the green and black wires that power the magnet? (Is it 50V?)
