I've "solved" an issue I was having with my BSD, but was hoping for a little education to make sure I've actually got the root cause.
When the mist ball is staged on the right side of the game, it travels right to left with no problem and re-stages itself fine on the left if not hit. If the ball is staged on the left the right side gate seemed to open early and close early before the ball got there, making the multiball active when you didn't earn it.
I basically just adjusted the switch on the right side of the game that the magnet triggers until the timing seemed good. It works now but the window is pretty tight, meaning the gate on the right seems to close up jussssst as the ball is about to fall out.
Is that magnet switch the only thing that controls the timing of the gate? I've seen a few threads that say C2 on the fliptronics board should be replaced for this issue...is that true? Or is it just a matter of playing with the switch adjustment?
Any tips and tricks appreciated to make sure I've actually flushed this out.
