So I was replacing LEDs in my BSD with the power turned OFF and now the lower GI and slings (including flipper guides) of the game (all below the mist MB) don't light up. As I was replacing, the lower GI worked (right side was done and I would periodically check to see them working) but when I started doing the left side with the machine still turned OFF, the entire GI on the bottom half (including the right side that worked seconds before) stopped working. Upper and all other lights remain fine.
I replaced all fuses related to GI (F106-F110) as I thought I blew a fuse but no luck. I took out all of the bulbs on the bottom left part of the GI no luck. Any thoughts on what else I can try? Thanks!
EDIT - also not sure what # is the GI for the lower half (F106 through F110). .....it might be F108 (yellow and white seem to connect the bottom).
EDIT 2 - it's the f108 fuse for sure. I just put a new one in and it's visibly changed after turning the game on. Going to try and remove all lights from this area. Any other thoughts?
EDIT 3 - This is going to have to be a one by one thing as I replaced all but one and it WORKS. I guess I'll leave this post up for those who might have a similar issue down the road but I believe once I figure out what bulb or socket it is, I should be good.
EDIT 4 - FIXED. Unplugged completely and put in one by one. No issues.
