Game off, reseat the ribbon cable on the back of the DMD and follow it up to the driver board. Reseat it on the driver board too. See if that helps.
You can pull the DMD out of BSD, take it over to T2. Remove backglass on T2, flip speaker panel down and remove power cable and ribbon cable and hook it up to the BSD display. Just be careful of the exposed back of the DMD will have high voltages present so don't touch or lay against metal. See if it's still the same. If it is the display is going. If the display looks good, probably the BSD driver board has an issue.
Quoted from schudel5:Game off, reseat the ribbon cable on the back of the DMD and follow it up to the driver board. Reseat it on the driver board too. See if that helps.
Excellent troubleshooting advice. With two games of the same generation swapping things around to find exactly what went wrong is a great method.
Agreed, excellent advice! Thanks so much. I will post my findings.
When you reseat the ribbon cables, reseat from CPU to DMD driver board to DMD. Get them back the same, red stripe pin one each end.
Quoted from LTG:When you reseat the ribbon cables, reseat from CPU to DMD driver board to DMD. Get them back the same, red stripe pin one each end.
Will do! Thank you. Also I should have mentioned. I have a rottendog driver board.
This page was printed from https://pinside.com/pinball/forum/topic/bsd-dmd-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
