Little backstory first - I have the Rottendog MPU board just in case that matters. My #BSD was running almost perfectly when I decided to add a spotlight to the graveyard area. I tested it out after installation, and it worked fine, and game didn't throw errors. I've been having an issue with the middle pop bumper being weak, so I checked that out after powering down the game (but I left it plugged in). As I was adjusting the switch, I felt a little shock but didn't think twice about it. Powered the game back up, and I was greeted with the F114 and F115 message. F114 continuity was good after taking it out, and F115 was visibly blown, and had no continuity.
Now onto the stupid part. I didn't have a 3/4A fuse, so I threw in a 3A fuse to F115 just to see if it would work after. F114 and F115 message went away, and I was getting some weird ground loop issues and check switch matrix errors for the middle pop bumper and drop targets, and I think a bit more, but I powered off the machine before I could take a picture.
I've since received 3/4A fuses, and when installing it to F115 it blows immediately. So, I've been going through the pinwiki troubleshooting steps, and have been doing well until checking for 12V at pin 2 of J114.
I had no fuse in F115 at first because I didn't want to continue blowing while testing. When I powered on the game with the J114 connector undone, I blew the main 8A power fuse for the machine. So after replacing that, and installing the correct 3/4A fuse in J115, I'm blowing the 3A fuses at F104 and F105 before I can even check for 12V at pin2 J114.
I'm hoping for some insight before I keep blowing through fuses trying to figure this out.
