(Topic ID: 23466)
BSD bats and rats quetion?
By dannunz
11 years ago
  • 16 posts
  • 7 Pinsiders participating
  • Latest reply 11 years ago by fusion301
#1 11 years ago
Im not sure but when i have 2 or even 3 balls locked and i get bats or rats all the balls are let through. I dont think this is sapossed to happen. Only for castle multi ball correct. It should only let one ball go for bats and rats rt. I tested the optos and they all work fine in switch test.
#2 11 years ago
I got this occasionally too. My optos all seemed to check out but I cleaned them anyway and it has seemed to solve the problem.
#3 11 years ago
Just took them apart and cleaned them no change. Any other ideas?
#4 11 years ago
Sorry I've got nothing else. I guess I was lucky and didn't have to dig very deep into it. I think it's a common problem tho.
#5 11 years ago
Should not happen, are they releasing from the castle lock? If so you may need to clean or check the parts for the release plunger possibly.
Mine has never done that in 2 years+
#6 11 years ago
If they are releasing from the through, you probably have flaky switches in there...
#7 11 years ago
Yes they are releasing from the castle lock. The release plunger works fine. Those are just optos switches and they are working fine in test. Is there an adjustment i can make software?
#8 11 years ago
It should release one ball from the castle lock for bats, but not for rats. If you cleaned the optos in the castle lock, maybe the release plunger is a little sluggish? If the game sees the right changes at the castle optos, it knows to stop releasing balls. Are multiple balls ending up in the shooter lane, or is it pausing to release another?
#9 11 years ago
No multiple ball are ending up in the sooter lane.
#10 11 years ago
Yes it only happens with bats.
#11 11 years ago
I mean yes they are all releasing at the same time into the shooter lane.
#12 11 years ago
I just did a little experimenting on my machine. If I stick my finger into the castle while there is a ball locked, it will release a ball. If I left my finger in there, the lock would keep releasing over and over, but the release plunger never has the little post lowered for more than a second at a time.
#13 11 years ago
+1 on inspecting/cleaning the castle release mechanism. probably dirty and not releasing correctly
#14 11 years ago
Ok with no balls in the lock the post goes up and down fine. But when there are balls locked the post is rubbing up against the pf. I will look at it tn and adjust it thanks guys.
#15 11 years ago
Yeah, my BSD did the same thing when I first got it. I adjusted it so that the releasing rod won't touch the PF and that fixed it. The contact with the PF was just enough to slow the rod popping back up down. Fix that and you should be good to go.
#16 11 years ago
Yes you may want to rebuild inspect that area closely - I also had a similar problem that seemed to resolve itself - probably when I was shopping it out I may have adjusted it it slightly and totally forgot about it. But it has to be fast and smooth to catch that next ball coming.
$ 12.00
Omaha, NE
YouBentMyWookie
$ 19.95
SilverBall Designs
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
$ 17.50
$ 5.00
Metal-Mods
$ 119.99
FlyLand Designs
$ 109.99
$ 399.00
$ 18.95
$ 1,059.00
$ 259.99
$ 5.00
RudeDogg Customs
$ 84.99
$ 46.99
Lee's Parts
$ 69.50
Lee's Parts
$ 329.99
$ 49.99
Metal-Mods
$ 27.95
9,500 (Firm)
South Bound Brook, NJ
€ 45.00
Kami's Pinball Parts
This page was printed from https://pinside.com/pinball/forum/topic/bsd-bats-and-rats-quetion and we tried optimising it for printing. Some page elements may have been deliberately hidden.
