Last issue after the LED job on BSD...plunger is auto firing and after it launches it will load another ball into the shooter lane, but that one doesn't fire. Just sits there until I hit the plunger button. And if the existing ball drains, it doesn't read end of ball until the second one is launched and drains. This happens for all 3 balls during a game.
I had a Switch 17 error, and that went away but the game is still doing the issue above. I checked the shooter lane and trough switches and engagement of the actuators, and everything seems fine. I did change the bulb in the plunger button, but even if the issue was emanating from there, I don't think that would cause another ball to kick out of the trough into the shooter lane...different switch. Either way, all the wires and actuator on the plunger button look fine. I did a switch edge test, and everything came up ok for the shooter lane
Any help or suggestions?
