I bought the Unicatch stapler from PinRestore, and after three staples, the thing broke. It's leaking air from the trigger area, which the manual diagnoses as damaged O-Rings. The problem is that the trigger area is the only part of the staple gun you seemingly can't take apart.
Has anyone had any issues like this with this gun? Were you able to fix it, or did I just light a hundred dollars on fire?
