Broken playfield metal post. Piece stuck in the hole
By Marcuni
6 years ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by jrrdw
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 6 years ago
My Pinbot is missing the left metal post on the visor. The one on the tip of the left plastic piece. Amazingly the plastic is still intact. This hole does not go through the playfield and I can see a piece of the original post in the hole. How do I get it out???
Also, what is the correct post and rubber that goes there? I've seen a couple different games that have different kinds.
This is not my game picture. It's just to show you where the post hole is.
#2 6 years ago
If its actually a post that is screwed into the playfield... and there isint anything to grab onto above the playfield you will probably have to drill it out or use an EZ out screw extractor. I don't know if they make them that small.
#3 6 years ago
i had to drill out and around a broken off post like that once. i cried, but there was no other way. Only chance you have is drilling through it like ssathre mentioned, but that takes a very high quality bit to be able to drill out another bit. i ended up filling the area with plastic wood. good luck.
#4 6 years ago
It's either that or nuke it from orbit... its the only way to be sure.
#5 6 years ago
Or just buy a new playfield....haha
#6 6 years ago
or you could just 'cut it in half' and part it out?
#7 6 years ago
IF it is threaded you can find some counter clockwise drills and attempt to drill it out. If the drill bites then it will thread it out of the hole.
#8 6 years ago
Quoted from Pugsley:
Quoted from ssathre:
#9 6 years ago
I'll give it a try this weekend. Thanks for the tips.
#10 6 years ago
Good luck! Let us know how it goes.
#11 6 years ago
These type post have pointy ends. Use a nail set and drive it out through the bottom. You'll have to do a little wood repair (Elmer's Carpenter's Glue) but it won't be visible from the top.
$ 18.99
$ 40.00
$ 22.00
2,000 (Firm)
Woodcliff Lake, NJ
$ 36.99
$ 12.99
$ 989.00
$ 7,299.00
Flip N Out Pinball
$ 9.99
$ 229.99
$ 9.95
$ 59.99
$ 44.99
Lee's Parts
$ 269.00
Note: This is an old thread. The last post was made to it 2,214 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
