(Topic ID: 192632)
Brightest LED #555 bulb
By Aniraf
6 years ago
  • 14 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by Aniraf
#1 6 years ago
Does anyone have a recommendation for a very bright LED #555 bulb? I want to do a better job of lighting the inside of my ringmaster on a CV machine. I switched to the purple version of the RM, which I really like, but the darker color blocks out more light than the default green one. At the time of writing this, I've tested a #555 I purchased from autozone, and it's actually more dim than the incandescent. :/.
#2 6 years ago
Is that a 12v bulb or 6.3v you wish?
#3 6 years ago
The Autozone bulb is probably 12 volt. What you need is probably 6.3
#4 6 years ago
Likely...6.3V Best bulb (diffused over 300 degrees) to light ringmaster head, bulb in head, Op-Max from Comet.
Brightest Bulb as a Spot in 6.3v is 1 Watt magnum at Comet, also available at Cointaker.
#5 6 years ago
These are very bright. Hence the product code... http://www.pinballlife.com/index.php?p=product&id=2560
#6 6 years ago
Just ordered a few of these because of the product code . Awesome! Thank you all for the suggestions!
#7 6 years ago
Quoted from Aniraf:
Cool! Let us know how they work out for you.
#8 6 years ago
Quoted from thundergod76:
Ok, so I got the bulbs and they are awesome…for five minutes :/. I put one in, and started playing. It was working perfectly, then all of the sudden it was dim. So, I took the ringmaster apart and put another one in, worked great…five minutes of playing later, it is dim?
This makes zero sense to me. I feel like the incandescent bulb was doing the same thing. Does anyone know what could cause this?
Here is a picture with a purple light that I thought looked pretty cool.
#9 6 years ago
Im guessing that it is a 12v Light, can you check the manual?
(First Question)
and with my apologies for my ego, trust me, you want an Op-max regardless....
I created this bulb for these purposes.
#10 6 years ago
Quoted from OLDPINGUY:
(First Question)
So the manual just lists the bulb, and the socket. I can try to get a meter on it in a little bit.
It also says "2" which is clearly untrue as the printed diagram of the ringmaster only shows one.
#11 6 years ago
Quoted from Aniraf:
That's a 12volt bulb. Meant to be a flasher bulb
#12 6 years ago
I dont remember on CV with 2 bulbs...is one always on and one flash?
Hi James!
#13 6 years ago
Hi James!
Nope, there aren't even two bulbs. This must be a misprint because later in the manual they illustrate the RM with only one bulb.
Screen Shot 2017-07-10 at 3.47.43 PM (resized).pngScreen Shot 2017-07-10 at 3.47.43 PM (resized).png
#14 6 years ago
Quoted from jrivelli:
Bingo...that's why this never worked for me! Someone put a #555 in there, and it was burnt out after I received the machine. I've been changing it and trying to fix it over and over, just to realize I'm using the wrong damn bulb!
I put in an incandescent #906, and it has been working ever since. Now I need to find the brigtest #906 LED bulb .
Thanks for calling that out, I don't know why I didn't notice it.
$ 69.50
$ 9.95
8,700 (Firm)
San Ramon, CA
$ 45.95
$ 1.00
Pinball Alley
$ 11,300.00
Yellow River Pinball
$ 37.50
$ 109.95
PinSound
$ 45.00
Just 3D Mods
13,000 (OBO)
Hudson, WI
Pinheadz
$ 10.95
$ 54.99
$ 399.00
$ 29.00
Pinball Photos LLC
$ 44.99
Pinball Shark
$ 1,059.00
11,300 (Firm)
Danbury, WI
$ 5.00
Van Alstyne, TX
This page was printed from https://pinside.com/pinball/forum/topic/brightest-led-555-bulb and we tried optimising it for printing. Some page elements may have been deliberately hidden.
