Thanks for your link, actually I went through it this morning.
I am confused with what is depicted there, compared to the schematic I attached. I perfectly understand the DC side, but the AC side gives me some problems. I see 2 wires 10 and 11 coming from a connector (based on the manual, they both have 9Vac, on each one there is a fuse)
- Are these wire the "ends" of the AC side ? In other words what is the path of the AC side ? I ask that because there are 2 wires coming from another connector with a diode on each (in reality, these wires are n.c. on the connector). And I am a bit consused with that.
- Why are there 2 fuses in this context ? One on each wire.
- I can measure 18Vac on the BR AC lugs, am I measuring correctly ? It is apparently the sum of the Vac of the 2 wires, what is the logic ?
- In the tutorial, the Vdc is a positive voltage on one end and a 0V on the other end. Here, according to the schematic, one end goes to a +12vdc connector, and the other -12Vdc. So I do not understand.
thanks a lot for your patience
