HI All,
I recently acquired a Bride of Pinbot in average condition. Cabinet has been nicely redone, but the play field and ramps need a work. All is registering and working electrically; except the left flipper. Left flipper switch does not register in switch test mode, all other switches register correctly. The left flipper specific fuse is good, and I have replaced it to be sure. At some point in its life, it has had its flipper mechs updated to use the more modern wpc style; i noticed that on the left flipper the EOS switch isn't engaged when the flipper is extended. This would effect the life of the coil, but doesn't explain why the left flipper cabinet switch does not register.
Any ideas? I am stumped.
Thanks in advance
