(Topic ID: 191885)
Bride of Pinbot Head Issues
By Pinball-DOOD
2 years ago
  • 22 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by Pinball-DOOD
#1 2 years ago
Hey all,
I have had my Bride of Pinbot for two years and just recently an issue regarding the head position appeared. Whenever she gets off position during gameplay, I'll go into test and undergo a Head Cycle and she will calibrate and function perfectly for 6 or 7 more games then she will be on the wrong face again. I have the schematics and have never worked on a Bride before (extensively). Could anyone point me in the right direction? Cold solderjoints on connectors? I'm stumped! Thanks!
The DOOD
#2 2 years ago
Is J138 supposed to look like this? Haven't got to check the book to see the purpose of this connector.
#3 2 years ago
Looks like it's for lamps, nevermind!
#4 2 years ago
This is common on bop. Check the solder joints on the relay board for the head. It's on the left upper portion of the playfield.
#5 2 years ago
Quoted from mollyspub:
Gotcha! Should I reflow header pin solder?
#6 2 years ago
Also check the adjustment on Switch 67 under the face plate. It controls the face position and is often the cause of problems with alignment.
#7 2 years ago
Yes. I purchased a second board just in case
#8 2 years ago
Quoted from BoP:
Ah, thanks. What is the common issue with that?
#9 2 years ago
Nice! Do I have to disassemble the head to reach the board?
#10 2 years ago
Not at all. When you lift the playfield, it's to the bottom left. I can take a pic if your not sure.
#11 2 years ago
Terrific! Thanks for the help, I'll update tomorrow!
#12 2 years ago
All fixed! Now I'm having strange issues that have been goin on for a while where sometime the game won't boot. I was told it was a 5 volt issue. Could anyone tell me how I could address this? Thanks!
#13 2 years ago
Quoted from Pinball-DOOD:
This should set you on the right path:
http://pinwiki.com/wiki/index.php?title=Williams_WPC#Game_resets
#14 2 years ago
Thanks! Time to reflow some more solder
#15 2 years ago
Just for ease, which connectors, compactor, and bridge rectifier would need to be reflowed? Could anyone take a picture? It would help greatly!
#16 2 years ago
What solved your issue with the head? I have the same issue but mine only pops up when I'm on face 3 and a ball drains and it should go back to face to but sometimes it will go to face 4 but the game will play like it's on face 2. Then recalibrate then ok. Where'd you get the extra board at?
#17 2 years ago
What version of the ROM are you running in the game? The later versions were supposed to handle the operation of the head better.
#18 2 years ago
L6 now. I got the have with L4 in it and can't remember having an issue but I don't thinkI paid much attention or ever got to head 3
#19 2 years ago
Quoted from Yesh23:
I just reflowed solder on the header pins on the little board to the left of her head (under playfield). Easy!
#20 2 years ago
Ah, she's getting it wrong again. Any other ideas?
#21 2 years ago
Just did a Factory Reset for the first time, she's doing well now!
4 weeks later
#22 2 years ago
Alright, seems to appear I'm having the issues again. Is there a connector on the Power Driver board I should reflow solder on?
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 279.95
Pin Stadium Pinball LEDs
$ 369.00
