I'm working on a BOP and have taken care of all the other problems including the relay with the head and I have no more errors, but when I went to put the faceplate on with the mouth hole the screw holes do not line up.
Thoughts?
Was kind of hoping the video would have stopped where you were trying to line the holes up at. Anyway, the mouth is the only panel that has different hole locations. The top screw is on the right and the bottom one is on the left. The spinning part attached to the motor should be a fixed location as it tells the game where it's at. The lower panel can be spun though to line things up.
yes, if you look at the 13 second mark where it stops for the mouth the hole on top is on the left not the right. Is there a way to change where it stops to have it line correctly?
Not that I am aware of. I thought it was self aligning thus why 3 out of the 4 have a those bumps for the switch to register at.
This page was printed from https://pinside.com/pinball/forum/topic/bride-of-pinbot-head-cycle-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
