(Topic ID: 253358)
Brass washer on relay location
By 4Max
#1 4 years ago
Hi folks, basic question coming up:
Which side does the brass washer go (this is a Gottlieb 1965 Hi Dolly). I am going through the switch stacks and some are mounted "behind" the frame and some outside. I searched on the forum, and advice is "between coil and the frame" but was not sure if that meant the frame the coil sits on, on the long frame all the coil brackets sit on
So I figured picture tells a 1000 words...is this correct? Or should the brass washer be "outside" that brass frame - thanks all!
#2 4 years ago
Next to the coil inside the relay frame
#3 4 years ago
Ok. Thanks. So above photo is correct. Have to adjust a couple that were not! Cheers
#4 4 years ago
Quoted from 4Max:
Yes, picture is correct.
#5 4 years ago
I recently had a burnt coil (A-9738) from a Gottlieb that had the washer on the inside with the coil. So I replaced it with a used coil (same id) and found that the points were all out of alignment. So I measured both coils and found that the replacement was longer by the thickness of the washer. Once I removed the washer all was good again. Could this be why he has this situation? Anyone else ever had this happen?
#6 4 years ago
Quoted from RustyRazor:
I understand the brass washer is located between the relay carbon steel core and the relay frame also carbon steel. Carbon steel can be magnetized brass not. That is the reason it needs to be there.
The burnt coil was nothing to do with the washer, best to put it back and fix the switch leaf points.
#7 4 years ago
Actually thinking back, the longer coil combined with the washer made it so that the coil was hard against the armature so that it couldn't even be retracted. Without the washer everything lined up and works just fine. I really did not have any other option other than to find a shorter coil. I am curios though, at what point did they change the parameters of the coil length? I have no idea out of which machine the replacement coil came from or how long Gottlieb produced coils with the same identification code. Maybe there is some old tech bulletin on the topic.
#8 4 years ago
If it was a newer coil with molded plastic over the end of the core, you should omit the washer. The plastic serves to insulate the coil from the frame, just as the brass washer does for the earlier style coil.
#9 4 years ago
Also remember that those coil hold screws must be brass, too. I always check Gottlieb EMs and occasionally find ones that have been replaced with carbon steel screws -- a no-no -- they can magnetize the frame. Because brass is softer than steel, the slots deform more easily when tightening, and some fixers think a steel replacement will work just fine.
This page was printed from https://pinside.com/pinball/forum/topic/brass-washer-on-relay-location and we tried optimising it for printing. Some page elements may have been deliberately hidden.
