(Topic ID: 163897)
Bram Stoker's Dracula - Speaker Panel Flasher
By PJKools
7 years ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by aeneas
#1 7 years ago
I just got my first project machine...Williams Bram Stoker's Dracula. I worked through all of the MPU battery damage issues and got the switches in order. However, I decided to attack the flashers next since the #26 Speaker Panel flasher wasn't working. It was wired to pin 1 on J124 of the Power CCA. since the flasher was not working I wired it "properly" according to the documentation which called out J128 pin 2. Well I believe that is what caused C11 on the Power CCA to go up in smoke...hope that's all it affected.
Does anyone know the proper wiring for this flasher?
Thanks in advance,
PJ
#2 7 years ago
Different machine but same story, flasher and coil captured between 20 and 70 Volt. It can blow C11
https://pinside.com/pinball/forum/topic/jd-slingshot-and-plunger-stuck-shut#post-2592986
Flasher #26 (Blu-Red) is on J124-2
#3 7 years ago
Thanks man...so the pin was wrong not the connector designation. That would have been my next step but I wanted hear it from someone else before I blew something else up.
#4 7 years ago
I made the same mistake about 15 years ago
The manual is incorrect, the label that's attached to the flasher connector is right.
This page was printed from https://pinside.com/pinball/forum/topic/bram-stokers-dracula-speaker-panel-flasher and we tried optimising it for printing. Some page elements may have been deliberately hidden.
